Trying to fit screenwash sensor in bottle and cannot find plug for sensor unit. Looked everywhere. Any ideas how to wire it in? Need help a.s.a.p as car in bits now on drive.
thanks
thanks
Anyone please? :-(
Maybe post in correct section !
If you haven't got plug then you will have to add wires to fusebox afaik ..
Irmscher Insignia CDTI 130
What do I need to do then?
I'm sure this has been discussed numerous times including in the TID to GID thread
The plug for it is taped to the loom for the windscreen washer pump, if its not there you'll need to go to a scrappys find a car with one and follow the wires into the UEC, pull the connector out of the UEC plug still attached(Yes pull it, it will come out pretty easy). There should also be a brown wire, thats the earth, just cut that. While your there open up the remaining loom and find a factory earth with a long piece of brown wire to us as the earth.
