Thread: CDC 40 radio
    Regular Member dave b's Avatar
    Nov 2007
    Wigan, Lancs
    Trim : Design LPG
    Engine : 1.8 vvt
    Mileage : 196,000+
    confused CDC 40 radio
    I have removed the cdc40 head unit from my 57reg design before it went to the breakers after an RTA.
    I didn't get the chance to 'divorce' it from the the car as it was not driveable.
    Is there anything I can do retrospectively to be able to re-set the radio?
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    There are companies on eBay who to be able to do it but the cheapest way is to get a car pass from Vx for your car the security code will be on that and that is all you need.
    Nov 2007
    Wigan, Lancs
    Trim : Design LPG
    Engine : 1.8 vvt
    Mileage : 196,000+
    Thought the CDC40 didn't have code as such, but had to be 'divorced' from the donor car using a Tech2 or similar?
    Obviously, I cant do this now with no access to the car it came from.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Did you not have a user pack / owners manual?
    If you did, then the code is on a paper credit card in the pack.
    If not, then you can get the display read - the display stores the VIN number from the vehicle you have
    (or PM me your registration number, and I will PM you the VIN number.)
    Take this VIN number or registration number and certificate of destruction to the dealer along with about £30, and you should get your pass after a couple of days.
    The VIN number will also be on any MOT certificates that you may have.
  1. Radio 1
    By vec-cal in forum Electrical & ICE (including SatNav)
    Last Post: 31st August 2010, 00:17
  2. my radio
    By the fisherman in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2010, 21:29
  3. CAN bus radio into a non can bus car
    By lennard2009 in forum Electrical & ICE (including SatNav)
    Last Post: 17th February 2010, 22:39
  4. CD 30 Radio
    By Stevel in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 13th July 2008, 17:15
