Thread: Cruise Control problem
    Oct 2012
    Default Cruise Control problem
    The other night, I was sat going down the motorway, at 75-80 with Cruise Control on, then all of a sudden CC cuts out, and the spanner shows up on my display for 2 seconds or so, I then drive without cc for a couple of minutes and its fine, put cc back on and it does the same again!
    Any ideas what it could be?
    Seems like I'm having issue after issue with this car
    Regular Member KeefyJ's Avatar
    May 2008
    Wolverhampton
    You don't say what your car is...
    I had similar on my 3.0CDTi Signum Eite (2008) quite a while back and the dealer traced it to a faulty switch whch was replaced under warrantee
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 137000
    Oct 2012
    I have a 2005 2.0 DTI
    The alarming thing is the spanner showing up on the display
    May 2008
    Wolverhampton
    Yes - the switch in my case was not (as far as I am aware) the cruise control switch but one of the others that is interlinked with the system...
    Oct 2012
    Turns out its a boost pipe, on front right handside, has a small split in, I guess at a certain speed is boosting and then ecu is picking up irregular readings and shutting off cruise control and throwing up engine management light
  1. cruise control problem
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2012, 22:07
  2. Cruise Control Problem
    By gsi.vxr in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2010, 13:16
  3. cruise control problem
    By Lee.. in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2009, 21:37
  4. cruise control problem
    By Herman in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2008, 19:10
  5. Cruise Control problem, HELP pls
    By Ridah in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2008, 11:06
