Results 1 to 10 of 11
Thread: radio code help and i have a car pass............
    wales
    confused radio code help and i have a car pass............
    can you help i have put the code in but no joy...
    is it the on the car pass,
    security code
    or
    radio type/code
    i put in the security code in with no joy
    Full Member Robsey's Avatar
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    As you have a 2004 vehicle, this could be either a full CAN or half CAN radio.
    If it is full CAN, then the radio code should be the same as the vehicle security code.
    If it is a half CAN radio, then it is the radio type / code number that you input.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Quote Originally Posted by Robsey View Post
    <img src="http://www.vectra-c.com/forum/attachment.php?attachmentid=64507"/>
    What he said :-)
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 137000
    Quote Originally Posted by signum driver View Post
    security code
    or
    radio type/code
    just checking you are entering code correctly
    press AS and turn the the stereo on while AS is still pressed in, when you see - - - - take your finger off AS, say your code was 4356 press number 1 4 times, number 2 3 times , you get the idea once you have entered code keep your finger on AS youll hear a beep and it will work
    11 Post(s)
    Quote Originally Posted by vectra ste View Post
    And also make sure the ignition key is switched to position one in the key slot else the coding proceedure won't work.
    wales
    thanks guys yes i know how to put the code in but not the code i need..here is my car pass,
    i have put the security code it three times and no joy..????
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    is this a replacement one you have bought from another vauxhall or the one that came with the car?
    wales
    came with the car
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    I see from your pass that the following details are probably correct
    Radio type = CDR2005
    Radio Code = 7481
    Radio serial number = 32018483.
    Suppose the first thing I would do is check that the serial number on the card, matches the serial number on the white sticker on the head-unit casing.
    If the serial number is correct, then the radio code should be 7481.
    I have heard of some instances where the CDR has thrown a wobbler, and will not allow itself to be programmed..
    This shows itself by not displaying the page with the dashes on..
    such as " CODE - - - - "
    In the worst scenarios, the head-unit has been faulty and could not be programmed or reset.
    If it is showing " 7 S A F E", then it is going through a wait period. (7 represents the remaining opportunities to input the code).. you would need to leave the ignition on until this page clears. After 3 incorrect entries, this wait period could be approx 15 to 20 minutes.
    11 Post(s)
    If it's showing 7 SAFE then you'll have to wait 20 mins.
    Attempt 1 - wait 10 secs. (Display shows 10 SAFE)
    Attempt 2 - wait 10 secs. (Display shows 9 SAFE)
    Attempt 3 - wait 10 mins. (Display shows 8 SAFE)
    Attempt 4 - wait 20 mins. (Display shows 7 SAFE)
    Attempt 5 - wait 40 mins. (Display shows 6 SAFE)
    Attempt 6 - wait 80 mins. (1 hr 20 mins) (Display shows 5 SAFE)
    Attempt 7 - wait 160 mins. (2 hrs 40 mins) (Display shows 4 SAFE)
    Attempt 8 - wait 320 mins. (5 hrs 20 mins) (Display shows 3 SAFE)
    Attempt 9 - wait 640 mins. (10 hrs 40 mins) (Display shows 2 SAFE)
    Attempt 10 - landfill. (Display shows 1 SAFE) ps, Re Landfill comment. Not really, but you would have to seek expert help to get it unlocked.
    And you have to leave the stereo switched on (and key in the ignition) until the wait time is over.
  1. where can i get pass code from?
    By stret in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2013, 22:02
  2. Car Pass - Result! Key Code & Radio Code
    By mxt in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 13:01
  3. Where would I expect to find my cars pass code
    By jimbojetset in forum Vectra C / Signum Car Chat
    Last Post: 23rd September 2010, 16:16
  4. car pass code?
    By mrk in forum Electrical & ICE (including SatNav)
    Last Post: 20th April 2010, 20:55
  5. Radio Code
    By Aaron1970 in forum Electrical & ICE (including SatNav)
    Last Post: 6th June 2009, 17:53
opel radio car pass
is radio code on carpass
icarsoft do u need carpass to work it vectra c
car pass radio code
vauxhall car pass radio code
