Results 1 to 2 of 2
Thread: Removing steering wheel
    Regular Member dti owner's Avatar
    dover
    Vehicle : SRI
    Engine : 1900
    Mileage : 180000
    Default Removing steering wheel
    Hi guys how easy is it to remove the steering wheel and put on another from ebay? Without letting the airbag off? Also how do younswap the airbag over?
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Before you work on any part for the Supplementary Restraint System (SRS) be it any airbags or seatbelt pre-tensioners, disconnect the battery and leave it 15-20 minutes to allow the system to fully discharge.
    Supposedly,to remove the steering wheel airbag, you insert a screwdriver into the holes on both sides of the rear of the steering wheel and press the spring retainers. At the same time (somehow) pull the airbag away from the wheel, far enough to undo the clips then unplug the connectors.
    Fitting is just the reverse, but be sure the plugs are fully in and the clips properly down again.... and don't reconnect the battery and switch the ignition on until ALL work is complete.... any SRS fault light requires Tech II to clear.
  1. For Sale: Sri facelift steering wheel c/w steering wheel controls
    By andy.l in forum Parts for sale
    Last Post: 3rd February 2013, 16:08
  2. Removing Steering Wheel Trim
    By CraigoT in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2011, 08:03
  3. Removing Steering wheel buttons
    By BigWilko in forum Styling
    Last Post: 5th January 2011, 10:54
  4. Removing Panel Under Steering Wheel
    By bennyk in forum Bodywork & Interior
    Last Post: 11th January 2007, 14:23
  5. Removing trim from steering wheel
    By Duncan in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2006, 22:07
