Thread: headlight adjust main beam
    Banned for Being a Numpty
    Jun 2012
    Default headlight adjust main beam
    can u adjust main beam? just been out in fog put my main beam on to see beam pattern and left side is pointing right over to the right anyway of adjusting it? also any one have a pic of there main beam on a wall??
    Jul 2011
    UK
    Year : 06
    U can adjust it but if it's pointing to the right I would take it too a garage to get alignment done so it's spot on
    Regular Member Zeus^'s Avatar
    Sep 2011
    Grantham
    How do you adjust them?
    I can see how to adjust the dipped beam with the little socket on top of the unit. Is there another one I cannot see?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    2 hex adjusters each sides. Nearest to radiators are up and down. Next one away is left and right.
    Look on top of headlight, find middle and that's point of flat to up angle on beam. Should help u make it middle again using left/right adjusting, if i remember, its 6mm hex
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Main beam i'm not sure. Might be underneath but i've not noticed!
    Jun 2006
    St. Helens,Merseyside
    its all 1 unit/set of adjustments
    make sure the bulb is in correctly.
    also the pic seems to be of the dip beam ?
    Jun 2012
    also ive noticed my beam is blurry at night,and have seen other that are quite sharp n cut off is wicked,mine seems to glare,if that makes any sense?
  1. main beam holder
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2011, 00:55
  2. Main Beam Bulb...
    By chewy71 in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2010, 20:27
  3. Main Beam won't stay on
    By KevinG in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2010, 00:14
  4. Hids in the main beam...
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2009, 20:50
  5. Main beam bulbs
    By Bucko in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2009, 20:49
vectra c headlight beam adjustment
