Results 1 to 2 of 2
Thread: clutch noise when pedal depressed
    Mar 2011
    Glasgow
    Default clutch noise when pedal depressed
    when the engine is warm and been running for a while say an hour or so and if i press the clutch down i hear a slight ringing/squeeling (like a dodgy bearing sound) but its slight,
    anyway it seems to be getting louder slightly, and happens randomly (would happen more so if I always coasting and kept clutch down) but sometimes it doesnt happen at all as I shift gears fast without coasting,
    is this the thrust bearing i presume? the clutch itself is perfect no issues, no slippage, etc.
    I am a bit skint just now and was thinking of maybe just changing the bearing plus clutch plate and leaving the DMF (no dmf noise over here!! seems to be well) and doing the job on my driveway, I have all the necessary tools
    what you guys think?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Take it's a 1.9? Does it rattle when the clutch is around half down?
  1. Grinding noise when clutch depressed
    By y2joeyb in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2012, 11:27
  2. DMF query, rumble at idle and if clutch depressed
    Last Post: 19th November 2011, 10:27
  3. Clutch pedal noise
    By danno in forum Vectra C / Signum Troubleshooting
    Last Post: 11th October 2010, 13:14
  4. Clutch pedal noise
    Last Post: 11th December 2009, 06:15
  5. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
vectra c noise when depreasing clutch
