Results 1 to 10 of 11
Thread: CD70/CID/Bluetooth UHP
    South West
    Default CD70/CID/Bluetooth UHP
    Quick Question..
    We know if a CD70 and CID are removed as a pair can be installed into another car. If the CD70 and CID also have a UHP bluetooth unit connected will that also work if removed from one car and installed into another?
    Rgds
    Aidi
    Moderator paulhb's Avatar
    Wondering lonely as a cloud
    27 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Yes it will with some minor programming as everything else needs to know its there easiest thing is to put it in delivery mode before selling on guaranteed no issues and whilst were are on the subject you can put your SRI leather into delivery mode for my car bud, oh dang already have SRI leather lol.
    Administrator plasma's Avatar
    On the Forum
    574 Post(s)
    Engine : 150
    Mileage : 74000
    yes
    South West
    Lol, You know where i am going with this dont you Paul!!! . As things were going through my mind earlier you did spring to mind and was going to ask when i had made my mind up if you wanted first refusal.
    Ok - now i am confused.... Paul says with a small amount of programming and dean says it will just work...??
    27 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Deans the expert go with him my programming was if you have delivery mode employed might still look at the leather Aidi got a mate who might be up for it let me know
    South West
    Will do Paul. if i go ahead with the Insigna idea, ill advertise the car as is and see what happens (px with vx would be joke) Failing that ill get out the gucci bits and do a px like for like with whoever wants the bits.
    It will wrench me to take all these bits out - lots of hard work by many people to the car to what it is today.
    Full Member Robsey's Avatar
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    I agree with Dean -
    Whatever you "had" as the Infotainment package will transfer as a complete unit.
    Programming may be required for the display to match it to the recipient car, such as ECC / SAC/ Air-Con etc, and also fuel type if you are using the BC function.
    UPDATE: -
    Programming will not require the donor vehicle's security code, as it will be Variance Configuration Settings or Code Index values that will be changed. - You will not need to put the unit into delivery mode for this stuff.
    Only divorcing, pairing or adding and removing indevidual components will require the security code.
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    Quote Originally Posted by Robsey View Post
    what exactly is SAC? I saw it earlier when i was poking around my car with my laptop... I know its something to do with aircon
    27 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Semi automatic air con between ECC and basic air con
    On the Forum
    574 Post(s)
    Engine : 150
    Mileage : 74000
    As all comments above...
    If your selling it as a lot, it'll be fine, they can fit it in and it will work. If you have your car pass just write the number on the top of the radio so they can then deal with gaining access to the variant config and adding/changing items they need to, like the aircon for example. If they have ECC and its programmed for normal aircon they wont get the numbers displayed on the bottom of the CID...
  1. cd70 bluetooth
    By XxelliexX in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2012, 20:58
  2. Bluetooth Kit - CD70
    By Larrymurphy02 in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2009, 12:54
  3. cd70 bluetooth
    By graham a in forum Electrical & ICE (including SatNav)
    Last Post: 13th April 2008, 17:27
  4. CD70 Bluetooth
    By mickyd98 in forum Electrical & ICE (including SatNav)
    Last Post: 27th December 2007, 20:45
vectra c uhp bluetooth
vectra c 2006 cd70 bluetooth pin
UHP Factory bluetooth
opel cid change uhp
bluetooth pin for cd70
