Thread: pesky upper timing chain guide bolts‏
    Oct 2011
    Bristol
    Default pesky upper timing chain guide bolts‏
    Hi All,
    Had a bit of a problem over the weekend while attempting to do the head gasket on my 02 2.2 DTI (Diesel). Iíve been following the Haines manual and to remove the bolts securing the upper timing chain guide it states heat up the bolt to degrade the loctite to help remove, well I tried this and manages to break 2 Torx 30 heads so Iím obviously doing something wrong. Has anyone got any idea how hot it needs to get? As both bolts look like they are in the head can I get away without removing the tensioner or is there another way around this?
    Noel
    Regular Member C-Owner's Avatar
    May 2011
    South London
    You need to heat them up to "dark red" sometimes.
    See chart in link below
    http://www.sizes.com/materls/colors_...ted_metals.htm
    Also try tightening a fraction before releasing.
    And us quality torx bits (Snap On) as the cheap ones will break.
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    might also pay off to use 1/2 torxs on a breaker bar - be carefull.
    Oct 2011
    Bristol
    Cheers guys. 'Dark Red' = 700 degrees C, ouch thats hot, I'm slightly concerned about
    heating the head that much, I wonder if I can get away without taking the guide out?
    May 2011
    South London
    Quote Originally Posted by Noeli0 View Post
    I did say sometimes "Dark Red" not all the time.
    Usually a good thorough heating will melt the loctite,
    but if the jobs been done before and you are doing other work like a head gasket,
    someone might have used a different compound to retain the bolts, loctite "Metal Set" for example.
    Oct 2011
    Bristol
    thanks C-owner, I'll give it a shot taking the head off without removing the guide, otherwise I'm a bit stuck as a dont have a gas torch - will see what the weekend holds
  1. Broken cam chain guide
    By Froggy in forum Engine & Drivetrain
    Last Post: 10th December 2012, 21:38
  2. Vectra VXR - Primary & Secondary Chain replacement Guide
    By peelmeister in forum Engine & Drivetrain
    Last Post: 31st July 2012, 12:50
  3. Upper inlet manifold bolts
    By Jonsey in forum Engine & Drivetrain
    Last Post: 20th January 2012, 20:47
  4. Caliper guide bolts
    By vec04 in forum Suspension, Wheels & Brakes
    Last Post: 28th May 2009, 23:23
  5. timing chain
    By dezzie in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2007, 22:05
