Results 1 to 10 of 29
Thread: Urgent help alarm keeps going off
    Regular Member johp778's Avatar
    Apr 2012
    Leeds, W Yorks
    Default Urgent help alarm keeps going off
    Hi AllSince I came home tonight my alarm keeps going off, tried it will interior sensors disabled, but still goes off. Is there anyway I can lock the car with alarm disabled until I can get it looked at, preferably without much mechanical interference, seen as it's wet, dark and I'm not very mechanical?
    I can't see anything obvious, don't think it's been doing it all day, just since I parked on the drive when I got home tonight, it went off within a few mins of locking it.
    Admin plasma's Avatar
    On the Forum
    183 Post(s)
    Engine : 150
    Mileage : 74000
    close all the doors except the REAR drivers one, and manually push down the lock button... Then finally push the lock button on the rear one and close it. Make sure you have your keys in your hand BEFORE you lock the doors.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Jun 2012
    Lincs
    and when you do manage to look at it, i have just had the same problem and it turned out to be something with the rear window sensors.. took them off, wired them together, jobs a good en all back to normal
    Apr 2012
    Leeds, W Yorks
    Thanks, the manual also says u press the lock button twice (deadlock) to activate alarm, so I've pressed it once only, just waiting to see if that works as well. Does anyone know if u can get alarm fault codes without going to dealer?
    Apr 2012
    Leeds, W Yorks
    Ok, that hasn't worked, tried what u said plasma and my tailgate isn't locked and rear no plate lights are on?
    Jun 2012
    Lincs
    when you lock the car does your alarm led flash fast when it should be lit solid for ten seconds?
    Have you tried pressing the alarm button inside the car then locking it (if your answer is yes to the above this may not work)
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 126000
    Apr 2012
    Leeds, W Yorks
    The led does flash, can't remember pattern and seen as the tailgate has now locked and no plate lights gone out, I don't want to touch it again unless alarm starts going off. I tried ultrasonics off, but alarm still went off, reading other posts it could be drivers door module, as when I push button down it doesn't lock all other doors like it sounds like it should. Looks like I'm gonna hav to get it plugged in to tech2 to check for fault codes
    Apr 2012
    Leeds, W Yorks
    Thanks vectra ste I might hav to try removing fuse 23 then and see if that works, funnily I have been using rear demister a few times today, but haven't noticed any lines not working, so something else to check in the morn. Lads at work will be laughing at me tomorrow, tellin me I shouldn't hav bought a vx
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 126000
  1. Car alarm keeps going off
    By si_hoss in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2015, 18:37
  2. Urgent alarm help!!!!
    By Mickey76 in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2013, 16:21
  3. *URGENT!!* HELP!! Car key fobs wont open the doors and alarm going off!!!
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2008, 20:52
  4. Astra G 1.8 SRi Alarm Problem URGENT!
    By aaruck in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2008, 13:00
  5. Urgent or not so urgent ?? Service Warning Light
    By martinh67 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2007, 09:54
vectra c alarm keeps going off
vectra c car alarm keeps going off
12 urgent help alarm
vectra c alarm keeps going off but no sound
why would a vectra alarm keep going off
car alarm keeps going off vauxhall vectra diesel estate
vectra c alarm button
