Thread: Fuel Flap Solenoid...
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Default Fuel Flap Solenoid...
    Always knew the fuel flap never locked, finally got round to looking at it, and there is no solenoid in there
    I have had a look on eBay and there appears to be two different ones available (see below), does anyone know which one I should have?
    1. http://www.ebay.co.uk/itm/VAUXHALL-V...item43b4ce4b7d
    2. http://www.ebay.co.uk/itm/VAUXHALL-V...item1e72cc20cb
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Second one buddy me thinks
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    They are both the same mate the first one just has the plastic case around it that the second one clips into just had to replace mine if you dont have the case which can be seen from inside the fuel flap go for the first one, all else go for the cheapest.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by paulhb View Post
    Ahh, not sure I have anything in there, I will have a feel about - cheers.
    Did you get a new one, or a 2nd hand one?
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    When you open the fuel flap there is a hole where the pin goes and 2 screw holes for the plastic case, if its missing there will be a big hole into the inner wing from the fuel filler cavity I got a second hand one and its fine check when you put it in that F15 I think in the REC isn't blown (7.5A) as it goes when the solenoid fails and this might be the case and why yours was taken out. It will appear that it only locks if the fuse is gone change the fuse and alls well with the replacement motor.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Great info, thanks for that.
  1. fuel metering solenoid
    By daviej in forum Engine & Drivetrain
    Last Post: 14th January 2012, 15:22
  2. Fuel Flap Locking Solenoid
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2011, 09:21
  3. 1.9 cdti sxi 2005 Fuel metering solenoid valve circuit????
    By Gaz_chandler33 in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2010, 23:47
  4. fuel flap cover
    By neverlandandy in forum Styling
    Last Post: 23rd September 2009, 15:41
  5. Fuel Flap- yet another problem.
    By Mowster in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2007, 16:48
vectra fuel flap solenoid
vectra c fuel flap solenoid
