Thread: ECC info gone from bottom of CID
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Question ECC info gone from bottom of CID
    I have a strange one going on... the ECC info on the bottom of my CID keeps coming and going. I can still operate the ECC but not as before, I do not get any of the info on screen from fans sppeds to temp zone changes etc.
    This started on the weekend. It comes back occasionally but then goes again. This morning I had a call from the site security saying my car alarm was going off. I decided to disconnect the battery and do a full reset. So with the battery disconnected i also checked every fuse just in case and all were ok. I reconnected the battery and the ECC info came back for a while during my lunchtime visit to my local vx parts department. However when i left the dealers to drive back to my office it was gone again.
    I have reseated the connections on the back of the ECC and it made no difference. I can't pull the CD70 as i do not have a set of removal tools with me, ( i do have some at home).
    Has anybody seen this happen before? I will connect up my laptop tonight and check for codes and try reseating the connectons in my CD70 and CID.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    its a loose connection between the ECC and the Screen (not Radio), its probaly the 2 Can-bus wires thats the problem.
    I think I remember this happening on my Signum a few years ago mate - fixed itself as far as I can remember...
    Jun 2009
    South Coast
    Question battery test
    driving home i noticed that it was switching tabs itself and would end up on BC, it could not hold a bluetooth connection either. I had no ECC info all the way home. I have plugged in my laptop and had a shed loads of error codes all canbus or electrical related. Main ones being no comms with the mid speed canbus items like the DIS, EHU and ECC.. another said low system voltage.
    I dug out my volt meter and noted the figures then checked my wife's vec to see what hers were then tried her battery in my car.. results are as follows:
    My 2.0T Signum
    My battery:- 300mah
    engine off: 12.11v
    engine on and lights: 13.74v
    Wifes battery:- 600mah
    engine off: 12:10v
    engine on and lights: 13.62v
    Wife's 1.8 Vec
    engine off: 12:57v
    engine on and lights: 14.07v
    So what do you make of that, is the alternator fubar?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Looks like the alternator may be starting to fail, from those readings, as lower readings from your car with either battery in
    Jun 2009
    South Coast
    Quote Originally Posted by kenp View Post
    will check this as well in a few mins...
    Jun 2009
    South Coast
    well thats 10 points to Ken for getting the ECC info back on the CID. the connection was indeed loose at the back of the CID..
    However my laptop battery is nuked now so needs to charge, I will plug it back into the car tomorrow evening to see what codes I have then...
    Engine : 2.2 Direct
    been there done that hopefully thats was it.
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Ken got the can bus but who got the battery and alternator on the phone earlier, I wish that it wasn't though bud
    Jun 2009
    South Coast
    do those battery figures look like i have a alternator that's no longer cutting it then? If it is on its way out I will take off and get it refurbed as mine has the uprated bosch pulley on it.
  1. Unplug EGR: Top one or bottom one or both
    By mtqn in forum Diesel Engine related
    Last Post: 8th August 2012, 22:36
  2. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  3. Baby’s Bottom
    By Tadpole in forum Detailing and Car Care Discussion
    Last Post: 17th February 2009, 18:43
  4. Bottom spoiler bit
    By Kinjo in forum Vectra C / Signum Car Chat
    Last Post: 21st August 2008, 08:36
  5. Top , Middle or Bottom
    By Penfold in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2007, 18:10
