Thread: Suspected oil cooler issues 1.9 cdti 150
    Sep 2010
    Plymouth
    Engine : 1.9 CDTi 150
    Year : 06
    Mileage : 250,000
    Default Suspected oil cooler issues 1.9 cdti 150
    Having just changed the cam belt and water pump thinking that the water pump was the issue for my water loss it now appears I have Mis-diagnosed.
    i have water running from behind the oil cooler on the back of the engine, it has got progressively worse over the last few days, to the point where it now loses a lot quickly.
    are there any issues that this may be? Is there a seal/gasket that has failed or is it something more major?
    any help would be appreciated as its my taxi and currently off the road ;(
    TIA
    Sep 2010
    Plymouth
    Year : 06
    Mileage : 250,000
    Some pictures of the area concerned
    this is where the water is coming from, the oil cooler on the back of the engine
    This one is the filter housing, what's worrying is the level of oil around here, this looks quite sinister ;(
    Sep 2010
    Plymouth
    Year : 06
    Mileage : 250,000
    So far I have removed the alternator, diesel pump (and lost the woodruff key ;( ) and an still no close to finding the issue, are there any hoses around this area that may give problems, I have checked the two that feed/return from the cooler and they are ok, are there any that run along the back of the engine or between the cooler and the engine? i am tempted to take the cooler off and inspect, however I'm not sure what to expect!! There appears to be 3x15 mm bolts and 2x torx headed bolts, once I undo those and remove the cooler from the car will I get any fluid/oil escaping?
    Sep 2010
    Plymouth
    Year : 06
    Mileage : 250,000
    Finally found out the issue......a core plug !!!!
    i have spent all day removing half the ancillaries on the engine just for a piece of metal that will most likely cost me less than a pound
    whats the betting the local stealers won't have one in stock?
  1. 1.9 cdti 120 (8v Z19dt) egr cooler gaskets
    By 2wheelstu in forum Engine & Drivetrain
    Last Post: 7th May 2012, 00:59
  2. 1.9 CDTI 150 - Issues
    By me9141 in forum Engine & Drivetrain
    Last Post: 27th April 2012, 17:56
  3. X-tra cooler for transmission oil on V6 CDTi
    By Hummelshøj in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2011, 19:57
  4. CDTI SRI Suspected Shock Absorbers
    By Vaux-Man-G in forum Suspension, Wheels & Brakes
    Last Post: 9th May 2008, 16:24
  5. Vectra V6 CDTi Auto -Towing Limit/Oil Cooler
    By solarvec in forum Engine & Drivetrain
    Last Post: 20th March 2008, 15:15
how do u know that oil cooler is bad on opel zafira 19 cdti
vectra c 1.9cdti oil in water
recall on vauxhall meriva oil cooler
vauxhall astra oil cooler
1.9 cdti oil in water
how to change oil cooler on vectra 1.9 cdti
vectra cdti 120 oil in water
zafira 1.9 cdti z19dt oil in the water
how to change oil cooler astra 1.9 150
oil cooler repair kitfor vauxhall vectra
vauxhall vectra c 1.9 diesel oil cooler
How oil does vectra 1.9 cdti take
oil cooler vectra 19 cdti
vectra c cdti oil pump problems
1.9 150 oil cooler
vectra 120 cdti oil in water
https:www.vectra-c.comforumshowthread.php174268-Suspected-oil-cooler-issues-1-9-cdti-150
vauxhall zafira 1.9 dti oil cooler diagram
vectra c 1.9 cdti cooler kit
vauxhall vectra c 1.9 cdti oil cooler
vectra cdti oil in water
vectra c 1.9ctdi oil cooler
how to take out oil cooler for astra 1.9
vauxhall vectra 1. 9 cdti oil cooler problem
1.9 cdti oil cooler
