Results 1 to 10 of 11
Thread: Actuator link rod
    Mar 2007
    Gloucestershire
    Default Actuator link rod
    Has anyone disconnected the link rod from the manifold motor to the swirl flap?? I was just wondering how easy this was. I have glued all the flaps (bar no.3) but whilst it still moves as it should, the bearing is goosed and it moves up and down as well as left and right so I am losing boost. I want to glue this one shut, but need to disconnect the link rod so that it doesnt throw up any fault lights (so motor keeps working but doesnt actually turn anything). Had a quick look whilst under the car but the motor seems to be lost deep in the back of the engine.
    West
    Although i know it's not visible from the top of the engine i do know a few have managed to do this
    Mar 2007
    Gloucestershire
    I thought it might be a case of either locating it from under the car or using a mirror from the top so that you can then locate it and guide your hand in!! I can see from an earlier post which included the Pierburg bulletin regarding the manifold there was a handy photo of the part so I can see what I am trying to locate but there seem to be a lot of peripherals in the way!!
    Will have a look this weekend whilst I am changing the oil.
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Quote Originally Posted by sri150 View Post
    I'd like to know how easy it is to disconnect aswel as ive also bonded 1,2+4, might aswel do number 3 until i get a new inlet
    May 2006
    scotland
    Would you not want to glue it in the open position?
    Mar 2007
    Gloucestershire
    Quote Originally Posted by wickedwillie View Post
    Yep, thats what I meant - need to bond it in the 10 o'clock position - , just like 1, 2 and 4!!
    Regular Member OzMoSiS's Avatar
    Jul 2014
    Camberley
    Engine : 1.9 CDTi
    Mileage : 140k
    bumping this one.
    I want to know how to check to see if the actuator link bar on my manifold has been disconnected or not. How would I do this? Thanks
    Apr 2014
    sheffield
    8 Post(s)
    Vehicle : vectra i
    Trim : sri
    Engine : 1.9 cdti 150
    Quote Originally Posted by OzMoSiS View Post
    bumping this one.
    Start the car and get someone to rev it , if the actuator is still connected you will see the swirl flaps move , even if the bar that connects them all is off or missing , number 3 should still move
    Jul 2014
    Camberley
    Engine : 1.9 CDTi
    Mileage : 140k
    What I would like to know, is if no3 does not move, then is it due to the rod being disconnected, or due to the motor being seized?
    As far as I have checked, no3 does not move, but that in itself does not mean that the motor has seized.
    Nov 2009
    newcastle
    If motor is seized it will flag a fault and put into limp mode (as did on mine)
    Chance the swirl itself has snapped on bottom or inside.
    Swirl 3 won't move as link is attached still or seized inside manifold.
    To see link it's easiest pull off the EGR and look down back of engine, thru a small gap against engine you will see the plastic link few inches down.
    Get large flat screwdriver and twist if you want to disconnect it, pushing etc didn't work.
    Then clean n glue in position.
    I didn't disconnect the link originally just doing 1,2 & 4. Crud build up then took out swirl 3 and motor seized.
    Only fix is new manifold or remap, went remap and also had egr sorted
  1. Swirl actuator
    By carl78 in forum Engine & Drivetrain
    Last Post: 13th September 2012, 11:44
  2. Replies: 4
    Last Post: 11th November 2011, 12:05
  3. actuator help?
    By daveypower in forum Engine & Drivetrain
    Last Post: 2nd April 2011, 16:19
  4. Turbo Actuator
    By frenchman in forum Engine & Drivetrain
    Last Post: 8th November 2009, 21:19
z19dth glue swirl flap site:www.vectra-c.com
