Results 1 to 10 of 15
Thread: misted rear windscreen
    Regular Member tiimi's Avatar
    Sep 2012
    anglesey, uk
    Default misted rear windscreen
    mist up a lot, and takes ages to clear when i turn on demist settings, dont think the heated strips are working ?? anybody got or had same problem ?
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    noticed mine was a little misty more then normal other day i opened the rear heat vents aimed to window to help demist.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Mine is the same, and my boot is totally dry. Just turn on your A/C and it will help clear it quicker.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Happens quite a lot when it is damp outside and temperature not all that cold. As said, use your aircon, with or without heat according to taste,it works a treat in demisting screens and freshening the cabin, it's not just for hot days. Also gives your aircon an often well-needed bit of use.
    11 Post(s)
    How often do you clean the inside of the rear screen (if ever)?
    The cleaner the screen surface, the less it should mist up and if it does, should clear quite quickly.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    id check the boot for water just incase and check the screen heater voltage as mine starts to de mist the second i press the de mist button.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    Any of you have a check safe message on the screen? Sometimes a sign that the window element is goosed!
    Also, be aware that when using the aircon for short periods of time not all of the removed moisture is ejected from the system and some of it can enter back into the car when you turn it off. Might make it fog up again.
    I tend to whack the heater on full until it's just about unbareable then open the windows a few mm. just enough so that the hot moist air can get out but no rain can get in It seems to get fid of quite a but of the 'loitering' moisture in the air.
    Sep 2012
    anglesey, uk
    cheers for replies. will aim rear vents towards window, also try the aircon. and yeah, i got window clean ocd so they never really dirty.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    check the fuse is in the right hole mine is 03 and someone here told me the same and i opened the fuse holder in the boot and guess what it was in the wrong holder and mine now works
    Sep 2012
    anglesey, uk
    can you tell me which fuse and where it should be please, not too clued up tbh with u. lol
  1. Rear Windscreen repair
    By Veccy55 in forum Bodywork & Interior
    Last Post: 23rd December 2012, 16:13
  2. Heated rear windscreen
    By alzsxi in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2009, 18:26
  3. rear windscreen problem.
    By TKD Colin in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2008, 18:45
  4. Rear windscreen wiper
    Last Post: 19th May 2007, 16:50
