Thread: Suspension noises!! Newbie needs some help!!
    New Member Adgti's Avatar
    Jul 2012
    Derby
    Question Suspension noises!! Newbie needs some help!!
    Hi gang! Had my Sri Dti 53 plate for a few months. It has developed what I would say as 'graunching' 'light crunching' sounds when the car is in motion even at low speeds. Broken spring perhaps? Car handles and drives well enough......just this grinding graunching sound!! Makes the Vec sound like a bag of nails inside the car!!
    Any advice would be appreciated thanks !!
    Adam
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Hi Adam .
    this is probably going to be a process of elimination
    Probably causes for the noises youve described warn top mount,s on the suspension , broken springs , warn ARB bushes , warn drop links , failing that warn radiator mounts .
    Of the above your despriction of the graunching noises makes me lean towards the top mounts fairly common for these to go on vecs .
    check your springs have not had the ends broken off again common .
    Any clunking noises you can usually put down to drop links/arb bushes being worn
    hth regards bob
    and still loving it
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    spray a bit of wd40 on the anti roll bar bushes.
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    is it a knocking or crunching if its a knocking mosr probably a drop link somewhere if its crunching my bet is the anti roll bar bushes
    spray some silicone spray onto the bushes and test drive it, if its quiet then change the bushes
    dont spray everything though as you wont know what item it is
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 136000
    as bobssignum said Probably causes for the noises youve described warn top mount,s on the suspension , broken springs , warn ARB bushes , warn drop links , failing that warn radiator mounts
    normally it happens when you go over speed humps its the drop links and arb bushes
    i would go with the radiator mounts or engine mounts
    click below. post 6
    http://www.vectra-c.com/forum/showth...adiator+mounts
    if it does it going over speed bumps most of time its droplinks and arb bushes
  1. Quick help needed - Suspension noises after fitting FKs!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 27th June 2012, 18:08
  2. 3.2 gsi noises
    By noudder72 in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 19:05
  3. suspension noises
    By john-d in forum Handling & Braking
    Last Post: 11th May 2010, 20:22
  4. Suspension & Steering Noises
    By phil79 in forum Suspension, Wheels & Brakes
    Last Post: 11th February 2009, 00:29
  5. Newbie suspension question
    By Si Jonz in forum Suspension, Wheels & Brakes
    Last Post: 4th January 2009, 23:41
