Results 1 to 7 of 7
Thread: Vectra C SXI question
    Sep 2012
    Aylesbury
    Default Vectra C SXI question
    I have recently bought a 52 plate Vectra SXI after owing Fords for a long time, I find it very good apart the very harsh ride. It seems to feel every single pothole bump in the road. My question is is it possible to change the springs or shocks to make it a softer ride?
    Regular Member gibbon7000's Avatar
    lincs
    First you need to find out for sure that there is nothing else that is causing the harsh ride. But yeah they can be swopped. I have no idea what sxi spring shock set up is but the Elite models have the best for comfort.
    Mar 2009
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    The sxi has an Sri setup hence it's probably hard
    Dec 2011
    Seaham
    If you have large diameter wheels and ultra low profile tyes, the side walls are very stiff, this could also be making the ride feel harsh?
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    track rod ends, droplinks, arbs and wishbones should be checked before anything.
    Ely, Cambridgeshire
    63 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Quote Originally Posted by paulvectrac View Post
    The early ones didn't, my old 03 plate one had standard shocks and springs, I fitted SRi ones to it for a while and then fitted a Spax PSX kit to it. The later SXi's were almost identical to SRi's but the early ones were massively different in spec.
    If you've got a 52 plate SXi and it's a harsh ride, then it sounds like someone's changed the suspension set up on it.
    Regular Member frasedeb's Avatar
    Mar 2009
    hull
    my 54reg sxi had sri set-up and was very harsh, now got 57reg exclusive and much more forgiving.
    Ring vauxhall dealer and ask for a price for springs giving your reg no., then ask if its sri spec.
  1. Vectra 2.2 question
    By Bogwolf in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2012, 06:59
  2. Vectra C Question
    By lee brown in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2010, 22:59
  3. Sorry question about vectra B
    By stubopvectra in forum General Chat
    Last Post: 18th July 2009, 09:23
  4. vectra b question
    By gizmo10119 in forum Vectra C / Signum Car Chat
    Last Post: 16th October 2007, 12:02
  5. Vectra GSI key question
    By Itsallrover in forum Electrical & ICE (including SatNav)
    Last Post: 2nd September 2007, 12:36
vectra c sxi
