Results 1 to 10 of 29
Thread: Looking for a 12v feed
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    Default Looking for a 12v feed
    Tomorrow i'm going to attempt to wire in the side lights to an alternative 12v feed so they come on when the car is unlocked but then stay on all the time. Any suggestions on a good place to take the supply from? preferably under the bonnet
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I took my live feed from the fuse box i had 2 spare slots so used one lol mine only come on with the ignition tho and would like them to come on wen unlocking the car so can you take a few photos while your doing it so i can steel your idea lol
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Are you putting a relay in, as a permanent 12v won't come on with fob.... You want them to fire on with fob, then stay on with ignition live so no need to use switch?
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Quote Originally Posted by Mark-R View Post
    You need to put a 5 pin relay in between the 12v feed, take a feed from the 12v and one from the dash illumination so one fires when normally closed, other when the relays open...
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Not sure what you mean Lee. I thought about using a relay and triggering from the dash illumination circuit but i tought there must be somewhere to take a straight 12v from
    There MUST be a 12v live that comes on with the fob and stays on until the car is locked again. The GID/Cid for example comes on when you unlock and is always on until you get out and lock....?
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Maybe take it from the GID then, never knew that...
    If I where to change mine so I didn't use the switch i'd just use a 5 pin relay and use an ignition live and 12v straight from battery.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by leemarksmith View Post
    Yeah, that's my backup plan. Do you know of an ignition live under the hood?
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Not off top of my head but one of the relays will fire up, just nick it off there...
    But like you said, if the GID is always on till locked, I might even swap my feed now you've mentioned that...
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    The only reason i wouldn't do it would be current draw. I'm planning on changing my LED angel eyes for CCFL rings and i'm a bit unsure of what they draw and what the capacity of the existing cable is.
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    But you can use the GID feed to fire the relay only and then a fused 12v from the battery to get the power you like...
  1. 12v feed on first key click
    By Al 22 dti in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2012, 13:33
  2. This car needs an insulated air feed
    By Tmd in forum Petrol Engine related
    Last Post: 8th June 2011, 08:15
  3. 12v feed
    By decks in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2010, 18:24
