Results 1 to 10 of 20
Thread: 2.2 direct timing chain kit part no
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    Default 2.2 direct timing chain kit part no
    been looking through the 2012 vx trade club book and can not find the 2.2 timing kit anywhere in this book, theres not one listed for the other models that use this chain either! nor is the kit for the 2.0t listed.
    anyone got the part number on the trade club?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    The Chain kit is not part of the Trade club parts list mate as a chain is not counted as a service item. Hope THIS link helps mate.
    These kits are all gen kits and include the NET tensioner. Beware of any Gen kits that are cheaper as they are more than likely to be old kits carrying the old type tensioner.
    May 2012
    northumberland
    the belts are available for all the others 1.8 etc in the trade book, so are wishones and drop links etc
    bit silly that belts are part of trade club and the chains aint.
    May 2012
    northumberland
    timing belt kit:
    1.8 vvt retail £100 trade club £71.51
    1.9 cdti 16v retail £117 trade club £83.66
    loads others listed.
    water pump
    1.8 vvt retail £60.50 trade club £45.94
    every other one also listed.
    followed by 10 pages of steering suspension, starter motors, exhausts - almost every thing!
    May 2012
    northumberland
    tie rod end outer lh rh retail £21.10 trade club £14.85
    Jun 2009
    Middlesex
    Be ready for a shock when you here the price.Your find it's cheaper to buy the complete cam chain kit comes with guides etc and worth changing the balance shaft chain kit.Change crankshaft seal while the cover is off.Will need new timing chain cover plus rocker cover and run new tensions with a oil and filter change.I think about 400 pound approx from VX.
    Jun 2009
    Middlesex
    When i said timing chain cover and rocker cover i mean the gaskets.I think the rocker gasket was about 24 pound timing cover gasket a little cheaper and the crankshaft seal about 14 pound from VX.
    South east
    Quote Originally Posted by 06sri View Post
    That's because belts have a specified replacement interval, just like air filters and engine oil does. Chains are supposed to last the life of the car, like they usually do on the Z20NET for example. Items don't get added to TC just because they've turned out to be a bad design and don't last as long as Vauxhall claim they do.
    Jun 2009
    Middlesex
    Problem with the chains are the hydraulic tenisoners.I had my cam chain jump a tooth and had to have cam shafts removed to check for bent valves.If chain rattles get it checked.
    Aug 2011
    Bristol
    Change timing and balance chain.
    Mine has jumped and I am replacing all 16 valves (most are bent), cylinder head re done and skimmed.
    Will be changing gaskets, water pump, piston rings, both chains and spark plugs.
    A little jump has meant more than £900 just on parts. Get the kit with the Z20NET Tensioner. Only 1 place I found sells this kit and even VX don't sell this tensioner and wont sell it to you unless you own a Z20NET.
    Last a lifetime my rear end!!!
  1. 2.2 direct timing chain
    By Paddy in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2012, 21:31
  2. 2.2i direct timing chain
    By LEEROB695 in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2010, 22:10
  3. 2.2 direct timing chain
    By degsy11 in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2009, 20:10
  4. Timing Chain 2.2 Direct
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 15th January 2009, 10:59
