Thread: Big Brake Upgrade
    Jul 2006
    Default Big Brake Upgrade
    Just ordered the upgrade kit from LMF
    along with some other ...ahem... 'bits'
    Just a quick question, though. I know the brake sensor wiring loom from my SRi won't be long enough, and i need to order a GSi one, cut them up, solder together etc, but...
    Can't I just run without one at all? Or will the mysterious on board computer just keep shouting at me?
    I would have thought that it would come with the kit, if not they are just £6 from the dealer, a GSi one should plug straight in.
    it won't as the end plug to the cars wiring loom is different......
    if you don't fit one it will still light up the warning light.. for the 12 quid it will cost i'd just buy the bits you need and make one up....
    Here, there and every where!
    When i fitted the kit everything fitted perfectly. Nothing missing and nothing to add.
    Changed the calipers and disks, sensor wire fitted back in ok
    Quote Originally Posted by Caterman View Post
    Thats what I would expect for a kit costing 400 notes !!
    when we did Plasma's we had big probs on his with the sensor wire being 2" too short.. it kept falling out of the socket so we fitted a GSi sensor wire which is longer to fit around the bigger calipers..the CDti one fitted the smaller discs alright, but just wouldn't reach the bigger one when routed as the factory did....
    The only problem is that the GSi sensor has a different plug to the CDti..and the LMF kit didn't have a longer sensor wire in it..So we were forced into making one up...Deans never had a problem since...All i can do is , like Tony, pass on the benefit of my experience..
    Strange Mark, as Tommy said, if you pay for a full kit that is what you should get The only problem i had was one of the bolts would not shift! i had to buy a new bolt and grind the old one off
    yep, i remember you saying... the kit that Dean got sold had no extended lead whatsoever..are you telling me yours did???.. would have saved Dean and me a whole heck of greif making it work correctly??...
    No m8, no extras at all but my lead refitted in the same place as on the old caliper. Maybe it had a longer one to begin with
    Pass..... we couldn't keep Deans lead in..... hence why i adapted a GSi 314mm loom to fit his car.....
  1. Brake upgrade help please
    By Angel1368 in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2013, 08:57
  2. Brake upgrade
    Last Post: 6th July 2012, 14:03
  3. Brake upgrade...
    By scotty84 in forum Handling & Braking
    Last Post: 6th October 2011, 12:41
  4. Brake Upgrade
    By lizard in forum Handling & Braking
    Last Post: 1st June 2009, 16:08
  5. lmf v6 brake upgrade
    By rorycarz in forum Parts for sale
    Last Post: 16th May 2007, 18:24
