Results 1 to 10 of 14
Thread: HIDs and auto-lights
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Default HIDs and auto-lights
    Right, I have decided to upgrade from 1x candlepower per headlight to HIDs. Can anyone tell me if there will be a problem with the auto-lights function I have fitted? At the moment the dipped beam comes on the instant I start up, but if HIDs take a longer time (however short) to get going will they be damaged at all by the instant switch on?
    Car is a facelift and the ECU has been changed to Xenons 'present' if that makes any difference. Ta.
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    I wouldn't of thought so, well mine seem ok anyway!
    6 Post(s)
    The only issue you might have in winter with the HIDs coming on with the light switch in auto mode is that they might not fire up if the battery voltage is slightly low and pulled down even more when cranking the engine. If that does happen, just switch the headlight switch off and back on again once the engine is running.
    I tend not to leave mine in auto mode anyway. Found it too dangerous on the way to work as there is an avenue of trees and my lights come on just as I exit the trees and then turn themselves back off again. Just so happens there is a T junction not far up the road from there and people think I've flashed them out. Eeeek!
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Yes, programming the UEC to put it in xenon mode will help anyway, at it will prevent the OBD to check for H7 bulbs and also turn off PWM dimming pulse voltage, helping the bulbs' health, and avoiding errors to show up.
    You should definitely do it when fitting HID. Original xenon bulbs are HID too, BTW : the term doesn't only apply to tuning aftermarket parts.
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    What ecu's do u change? Also Is it afl??
    Apr 2008
    Noumea
    Trim : Elegance
    Mileage : 75 000
    AFL is rather related to additonal external modules.
    Here you just need to inform the UEC about how to properly power and check the bulbs.
    The UEC is the "underhood Electric Centre", so it's actually just the fusebox by the battery side : there's an electronic module in the bottom.
    You'll have to program a variant in it using the garage's Tech2 or a Vaux-Com.
    Some of the possibilities are described here :
    http://www.vectra-c.com/forum/showth...11#post1911111
    Page 1
    Xenon Headlamps - Not Present / Present
    I couldn't find any allusion to "xenon" in the different models descriptions, so the option should luckily be available to yours, whatever the series...
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    yeah all have a look, what about these daytime running lights ive tryed them all- 1 is the side lights on, but they dont go dim or anything which would be handy, 2 i think is just low and a think 3 is both not quite sure about that cant remember, and 4 nothing happened must be a different circut. would be good to have the dimming function.
    Apr 2008
    Noumea
    Trim : Elegance
    Mileage : 75 000
    What dim function are talking about, and what would you want them to do ?
    I'm personally intending to use the angel eyes rings as DRLs, but I wouldn't want the tail lights nor number plate to light up (I think it's still possible if I don't activate DRLs in the REC, but only in the UEC), and maybe dim the front sidelights in real (night) sidelights mode, but the most important feature I'd like is NOT having the instrument panel nor board computer going to night lighting mode...
    Do you think there's an available mode for that ? Else I'll use external electronics... Which we can discuss if you want.
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    116 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto LPG (with LUBE)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Quote Originally Posted by rozzer2006 View Post
    4 activated my front fogs as DRL's on my preface 2004 3.2 Gsi (half can).
    I should add that they are in reduced light mode, go off when sidelights/main beam are selected (or when engine switched off), and go to full power when used as normal via the fog lamp switch.
    Apr 2008
    Noumea
    Trim : Elegance
    Mileage : 75 000
    I had time to try some options this morning, as I had to check if my Op-Com update was working.
    Pre-facelift too, OEM xenon and fog lights :
    Mode 1 and 4 do nothing ;
    Mode 2 and 3 light the xenon low beams when the engine is running.
    What is mode 1 supposed to do ? I'd like to have the sidelights on...
    None of them did light the instruments panel, which is OK for me.
  1. Auto lights
    By kantimpalo in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2008, 15:45
  2. Auto Lights
    By Perry in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2008, 22:34
  3. Auto lights help
    By big nath in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2008, 19:18
  4. Hids lights for sale
    By ilaing in forum Parts for sale
    Last Post: 5th June 2008, 22:15
  5. Auto lights not very auto
    By Craig Rogers in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2008, 22:29
