Thread: Parking light, check left
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Parking light, check left
    I am sick of this... The brake light check left keeps popping up too. The cluster isnt a good one as 3 need replacing. (estate bulb holder that attach to cluster) but main issue is the parcking light check left is at front and i dont see the issue. Any advice??
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    First thing to do is try changing the bulbs as they go high resistance when they get older and it's enough to trigger the bulb warning, even if they're still working, they may not for long.
    However, the problem I had with my estate doing this, was that the connections in the rear clusters had corroded just at the points the bulbs touched and had worn away. I fixed this "temporarily" months and months ago, but adding a small strip of metal inside the connector that touched the bulb further round and made a good connection with the holder where it wasn't corroded. You can buy replacement inners for the clusters without having to buy the whole light unit though which is what I will do eventually.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Yeah, u can get the bits. On ebay if i can recall, 4.19 for one!!! I'll quickly look it up and post link. I'll ask seller if he'll do them cheaper for me and other members on here who needs one. If i remember correctly. 3 clips in each side. Am i right ian?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    http://www.ebay.co.uk/itm/250923960208?redirect=mobile
    Slightly reduced but still expensive for a small thing!!!
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Usually things like that are cheaper from the dealers...
  1. Check parking light?
    By krazylegz in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2012, 15:19
  2. Check right parking light
    By ian mc in forum Electrical & ICE (including SatNav)
    Last Post: 27th July 2009, 21:31
  3. Left parking light
    By otto in forum Suspension, Wheels & Brakes
    Last Post: 25th June 2009, 20:18
  4. Parking light check bulb light on and wont go off
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2008, 12:03
  5. Check right parking light.....
    By ROB WOODHOUSE in forum Electrical & ICE (including SatNav)
    Last Post: 16th November 2006, 23:39
check left parking light
