Results 1 to 10 of 15
Thread: Vectra 1.9 CDTi, 120 ps 8 valve or 150ps 16v
    Kent
    Default Vectra 1.9 CDTi, 120 ps 8 valve or 150ps 16v
    Hi Guys and girls
    Need some advice
    Looking to buy another Vectra. Got to be diesel
    Had a 150 16v 2006 which was fab.
    Have been offered a 58 plate 8v 120ps.
    I was lead to believe that the 120 was a Fiat engine.
    Are they more/less reliable than the 150ps? What are the pros and cons between the two engines.
    Your help would be very appreciated
    Paul
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I've owned both. The 150 was quicker and more economical.
    Currently own the 120. No swirl valve problems and no 3rd injector issues with this model.
    Other than that, usual checks apply... DMF, thermostat, EGR etc....
    A few people have reported cold-start issues with the 120. Mine's been fine so far though
    Both will go on for ages if looked after and serviced well. My 150 had 146k miles on when I sold. Currently the 120 has 134k on it.
    They are both Fiat engines mate, apart from that I don't know much else.
    scottish region
    The 120 is more economical but 150 deffo quicker especially with remap
    Kent
    Thanks Guys. Didnt know they were both Fiat lumps.
    Suppose you pays your money and takes your choice.
    Regards
    Paul
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Signum 2.0 DTI (Irmscher)
    Trim : Elegance
    Engine : 2.0 DTI 100 bhp
    In the terms of driving then the difference between the 120 and 150 is absolutely night and day.
    Given the choice it would be 150 all the way.
    Each have their own problems but overall the 150 will provide the smiles, unless your an econ warrior then the 120 may suit better.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    The 120 is generally known to be the more reliable however by that sort of age even the 150 had upped its game reliability wise.
    The only thing that wasn't really cured was the dmf and egr problems but you'll get that on either of the engines (although a dmf would be expected to last a little longer on the less torquey 120). The 120 will also see about 160 brake with a decent egr delete remap.
    Fuel economy is not actually that different between the 2 and you could end up finding that the 120 uses just as much as a 150 as it has to be pushed that wee bit more. Insurance and tax is also nearly identical in both so for that fact I'd go for the 150 as opposed to a 120
    RINGWOOD
    well i would be 50/50 if i had to buy again , i had a 120 with a dtuk box on , very reliable only rear arms and egr went.
    the inlet swirl problems put me off 1st time around on the 150 but if i was offered one with this already done i"d probably snap it up.
    i used to see loads of 150"s go past me and thought why didnt i get one of those . also 16v v 8v - bit more flexibility on the revs as def the 120 was flat unboxed.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    there have been a few threads on here regarding shall i buy the 120 or 150
    here is one
    http://www.vectra-c.com/forum/showth...on-what-to-get)
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
  1. 1.9 CDTi 16v 150PS EGR Valve
    By SRiXPT in forum Parts for sale
    Last Post: 26th June 2010, 22:17
  2. New Car: Vectra SRI 150PS!!
    By barkzz in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2009, 11:29
  3. 1.9 150ps CDTi Power drop in first
    By bandrew in forum Engine & Drivetrain
    Last Post: 21st August 2006, 21:19
1.9 cdti 8v vs 16v
2008 cdti 120 8valve gear boxvectra 120ps vs 150psvectra 1.9 cdti 8v or 16v 1.9 cdti 8 valve swirl valveis my vauxhall vectra cdti a 16v or 8vhow do you know whether vauxhall vectra is 8v or 16vvectra c 1.9 cdti 8 valvevectra cdti 8 valve and 16valve difference8valve vectrahow do i find out if my vauxhall vectra diesel engine is 8 valve or 16 valve Vectra c 8 valve or 16are the vectra 1.9 8v and 16v different how to find out if my cdti 150 is 16v or 8v
