Thread: vec-c aerial
    Regular Member fiend61's Avatar
    Nov 2011
    york
    Vehicle : vectra 2.8 turbo
    Trim : elite
    Engine : 2.8 turbo
    Default vec-c aerial
    hi all
    just another quick question can i get an aftermarket aerial and base for my vec-c, i need it to be gps and am/fm, just had price from stealers and noway do i want to pay £135 plus vat
    TIA
    Nov 2011
    york
    Trim : elite
    Engine : 2.8 turbo
    bump
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    if you need GPS (let's say you've swapped in a CD70 Navi) then you may as well stick with the FM antenna you have and just buy a Fakra GPA antenna and mount that - a popular and successful place is under the front centre dash vent (clear view of the sky as it's looking straight up through the screen).
    Nov 2011
    york
    Trim : elite
    Engine : 2.8 turbo
    no its not a cd70 its the standard ncdc2013, i think my aerial is on its way out, getting bad reception andalso the satnav wil turn red going under a motorway bridge thoug i would change teaerial and base first before delving deeper, just wondering whether there was a cheaper way than the stealer route? unless anybody can suggest other things to try? radio reception is worse when rear screen demister is on? its an 03 plate 3.2 elite with ncdc 2013 and colour screen
    TIA
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Gps wise get one cheap from ebay... But there are complete ones to Refit to yours
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    The old symptom of reception worse when rear screen on does seem to indicate aerial base water ingress/corrosion, so you might be looking at replacing that anyway. First things first though... get it stripped off and any corrosion wire brushed away, then if it works fine, just think about resealing the base to the roof - careful use of silicone may be appropriate there... and a hell of a lot cheaper than buying new.
    Nov 2011
    york
    Trim : elite
    Engine : 2.8 turbo
    thanks for the replies but have already had the aerial and base off of the car and no water ingress at all, also had a look at connections in aerial base , blue connector and also at the joint drivers kick panel (didnt know what i was looking for) but everything seems fine, what i want to do is swap aerial and base cheaply so i can see whether that is the route to take (if you see what i mean)
    TIA
  1. vec c aerial
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2012, 21:33
  2. aerial
    By matreya in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2012, 15:42
  3. How much is a new aerial?
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2010, 15:00
  4. tv aerial
    By VEC-MAN in forum General Chat
    Last Post: 28th February 2010, 12:41
