Results 1 to 10 of 19
Thread: My turn with P2279
    Engine : 1.9 CDTi
    Default My turn with P2279
    Car went into limp mode today when decelerating in gear.
    Egr has been cleaned (Wasnt that bad as I have the Fiat EGR gasket fitted).
    Checked the 2 vacuum hoses going to the valve by the battery/rad and one looks a bit perished but not holed. When I pulled it off vacuum escaped so its doing its job (Unless its closing/collapsing on deceleration). Ordered some vacuum hose anyway and going to replace then perished bits.
    Whats next lol
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Intercooler pipes ??
    Engine : 1.9 CDTi
    Had a quick look and cant see any splits and boosts fine.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 137000
    Quote Originally Posted by lee gsi View Post
    Whats next lol
    i found this
    P2279 is an air intake fault of sorts. Possibilities, working your way down the air intake path (not sure these would all give the P2279 fault though):-
    1) Clogged air filter
    2) Faulty MAF sensor
    3) Hose leak from MAF to turbo
    4) Turbo problems - including vacuum hoses
    5) Hose leak from turbo to intercooler
    6) Leaking intercooler
    7) Hose leak from intercooler to throttle housing
    8) Throttle housing fault
    9) EGR fault
    10) Inlet manifold problem, icluding swirls
    11) Boost sensor fault
    The vacuum hoses (2 thin hoses from the near right of the engine bay as you lead in - on a 120ps, not sure about 150) are common failure points. They tend to perish and eventually split at the elbow joints. You may not see the splits without flexing the elbows.
    Then check for splits in the intake hoses - the ones either side of the intercooler are prone as is the intercooler itself, but you would usually hear a whistling.
    If no luck, the MAF sensor attached to the airbox is the same for a 120 and 150, so if you know someone with a good one, it's a 2 minute swap out.
    Good luck!
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 137000
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 137000
    Engine : 1.9 CDTi
    Valve moves fine and the solenoid also moves in and out fine.
    If it is the egr rather than buying one I will get it mapped out (And the dpf at the same time)
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    What's you maf voltage?
    can you get access to smoke pro or similar?
    Engine : 1.9 CDTi
    Yeah will use the works 'Smoke Pro' Monday.
    Its fine under normal driving but if I give it some welly 'then' decelerate thats when the code comes up.
    Engine : 1.9 CDTi
    Not had a chance to use the smoke pro yet.
    But chanced the vacuum hoses and cleaned the boost sensor and that didnt make a difference.
    Just fitted another egr valve so will see if that makes a difference.
    Old egr valve I cleaned and the electric plunger bit was clean and free moving.
  1. help p2279 grrrrrrrr
    By gus evo in forum Engine & Drivetrain
    Last Post: 12th July 2012, 08:21
  2. Fault code P2279?
    By Phil MC in forum Engine & Drivetrain
    Last Post: 8th July 2012, 19:29
  3. P2279 code. 1.9 150
    By Mopar Man in forum Diesel Engine related
    Last Post: 28th April 2011, 20:45
  4. p2279 error
    By steve1412 in forum Engine & Drivetrain
    Last Post: 10th February 2011, 20:42
  5. P2279
    By rob123 in forum Engine & Drivetrain
    Last Post: 26th June 2010, 09:49
