Thread: boost presure
    Oct 2012
    lostockhall
    Default boost presure
    Hi had a new turbo fitted an im just wondering what the max pressure the turbo should be able to produce
    it has been run in over 400 miles
    oh its 1.9 cdti sri
    maximum its been to using torque pro to read is 21.9 psi
    Oct 2012
    lostockhall
    bump anyone?
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    Stock engine shuold boost 1,4 bar (20 psi). It could be litle different with the tool you mentions. If you have op - com it will be more excact. Does it seatle av 21,9 psi og is it a peak? It can peak, but seatle at 20.
    Oct 2012
    lostockhall
    its peaking there at 21.9
    looking at the logged data its actually peaked a little higher today 22.8 its reading off the boost sensor same as op com /vaux com does
    seems to settle at 21 its hard to get it to a point where the boost stays at max for a long period though
    Thanks for the info the garage thought that it was low
  1. presure washer
    By marc vectra sri in forum Detailing and Car Care Discussion
    Last Post: 24th February 2012, 21:52
  2. tyre presure??
    By byers in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2010, 22:01
  3. presure boost valve
    By reeseandellie in forum Engine & Drivetrain
    Last Post: 18th April 2010, 03:56
  4. boost presure valve
    By reeseandellie in forum Electrical & ICE (including SatNav)
    Last Post: 15th April 2010, 20:21
  5. boost presure control
    By cambis9 in forum Engine & Drivetrain
    Last Post: 2nd April 2008, 17:51
