Thread: Leg posistion reletive to Clucth's biting point
    Apr 2012
    Default Leg posistion reletive to Clucth's biting point
    Hi,
    Since owning a Vectra Iím trying to find a suitable seating position to enable a more reliable & comfortable seating position relative to the clutch.
    Iíve moved my seat to a position which enables to be closer to the biting point when I disengage the clutch. E.g: The clutch engages at about 50% ; my foot to clutch travel is at about 40%.
    Whilst this is my preference I am unable to fully depress the clutch against the back of the footwell . I am only able to do so by fully stretching my leg, which is uncomfortable.
    Would this set up in any way damage the clutch? Has anyone heard of the clutch-stop modification?
    Would the modification help me achieve this my desired setup in a more comfortable way?
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Just sounds like you need to sit closer to me? Are you really tall or long legged?...
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by Panacea View Post
    Hi,
    Since owning a Vectra I’m trying to find a suitable seating position to enable a more reliable & comfortable seating position relative to the clutch.
    I’ve moved my seat to a position which enables to be closer to the biting point when I disengage the clutch. E.g: The clutch engages at about 50% ; my foot to clutch travel is at about 40%.
    I'm a bit like that. 30 inch leg and about 5' 10 tall but I've got oddly long arms so if I pull the seat forward a bit, my arms end up really bent.
    Regular Member Sierra2's Avatar
    Sep 2010
    London
    Trim : SRI
    Engine : 1.9cdti (120)
    Mileage : 45k
    Personally, I would like to make my hydraulic clutch much stiffer, firmer. Any ideas if this can be done?
    South east
    Quote Originally Posted by leemarksmith View Post
    So you can put your arm around him?
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by Rebellion View Post
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Grab yer coat Panacea, by the accounts of this thread, you've pulled.
  1. Rattle on biting point
    By briancdti in forum Engine & Drivetrain
    Last Post: 9th March 2014, 10:49
  2. Replies: 26
    Last Post: 1st March 2012, 20:49
  3. Clutch Biting Point
    By si_hoss in forum Engine & Drivetrain
    Last Post: 16th March 2011, 10:08
  4. Need help, knocking noise at biting point
    By qianjizhao in forum Engine & Drivetrain
    Last Post: 26th November 2010, 16:22
  5. Very high clutch biting point
    By NikNaks in forum Engine & Drivetrain
    Last Post: 24th February 2010, 13:46
