Results 1 to 3 of 3
Thread: A few issues..........
    Oct 2012
    Derby
    Default A few issues..........
    Hi everybody, I'm new to vectra's so I'm sorry in that respect.
    First issue - where the clock is and youve got the radio station chanel ect, there's a bit where I believe the temperature should be...... The temperature is not showing its just abit like this (--.-). What could be the problem?
    Second issue - the passenger window won't go down with the passenger button, but the drivers side control can make the window go up and down. If that makes sense.
    Third - I can't seem to change the radio station? It's all just presets it won't find anything else?
    Forth - probably not in the right place but the car mists up very quickly? All the time.
    Its a vectra c 2004 1.9 cdti.
    Any help would be brill!
    Thanks.
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    on the first on it probablt the connection to the outside temp sensor. the sensor fits behind the lower front grill. if your car is a facelift the connection that fails right at the sensor, if you have a preface it the multiplug connection behind the bumper. they get corroded or sometimes just a wiggle of the wires will get it working. If still not joy you can pick them up for a few quick or cheaper from scrapyard
    EDIT: i see yours is a preface car so check the multiplug connection for corrosion
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    For the second issue, take the passenger door switch apart and clean all the contacts, very common problem, takes about 5 minutes, there's a howto for it in the howto section.
    For the fourth issue, you've probably got a damn/wet pollen filter, change it for a new one and make sure the drain hole under it is clear and not blocked.
  1. EGR Issues
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 30th June 2012, 11:51
  2. GID issues
    By kensbey in forum Electrical & ICE (including SatNav)
    Last Post: 11th May 2011, 17:46
  3. Issues!
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2011, 01:13
  4. Would I have any issues with...
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2008, 19:07
  5. mp3 issues with cd 70
    By jeff_g in forum Electrical & ICE (including SatNav)
    Last Post: 6th June 2008, 22:27
