Thread: poor start solved
    May 2012
    St ives
    Default poor start solved
    Starter motor. Fitted yesterday. Starts a treat. After new thermostat glow plugs battery etc. It was the starter motor. If you have the old poor starting problems go for motor first.
    Sep 2011
    Co. Durham
    Did your starter motor seem to work ok before replacement? Mine turns the car over and it seems like the car is going to catch and fire up but it wont if you let go of the key at that point I need to keep the starter turning after I would normally have stopped cranking the engine.
    Cheers Mike
    Carnoustie
    Mine has a similar problem, it's strange it seems to judder like it will not catch but normaly does start, have changed glow plugs, Alternator and battery, starter motor seems lively enough so I ruled it out?
    Ronnie
    Aug 2012
    Its a common problem from cold. If the starter motor isn't cranking fast enough it will fail or start poorly. It can sound like everything is cranking normally but its just not quite enough. However there are always a lot of much cheaper and more likely thing to rule out before spending money on a new starter.
  1. Solved my Start-up Problem, How weird!
    By spikeyboi33 in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2013, 22:15
  2. Poor start from cold ?
    By VecPower in forum Engine & Drivetrain
    Last Post: 23rd April 2011, 20:10
  3. Poor start up on ignition
    By JJGSI32 in forum Engine & Drivetrain
    Last Post: 29th June 2010, 22:17
  4. 1.9 cdti poor start...!!!
    By rioni in forum Engine & Drivetrain
    Last Post: 26th March 2010, 21:24
  5. car wont start and poor running help pls
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 3rd January 2010, 21:16
