Thread: Check Right Brake Light
    Jun 2009
    Middlesex
    Default Check Right Brake Light
    Have warning on central display saying "Check Right Brake Light" + Bulb symbol.All 3 brake lights working.Any ideas?
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Put in new bulb anyway and see if warning disappears?
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    Bulb might be on its way out but not gone yet. Happened with my headlights - bulb warning on dash but all functioning
    Regular Member C-Owner's Avatar
    May 2011
    South London
    High/low resistance on a failing bulb triggering the "Check Right Brake Light"
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Dobs
    take a look at the lights with someone in the driving seat,i think you will find one of the brake lights is illuminated higher than the other.when a brake bulb fail's the ecu uses one of the four side light bulbs,one of your stop light bulbs will have blown
    Jun 2012
    Edinburgh
    I had the same problem. changed the bulbs and everything's ok now.
    Jun 2009
    Middlesex
    Just looked at the lights in the dark.With foot brake on the right stop light is bigger than the left. With the side lights on,the l/h side light is bigger than the right.Fault was "check right brake light"
    Jun 2009
    Middlesex
    Thanks for the info.From what has been said sounds like the ecu is using one of the r/h tailight bulbs.Will get a new bulb and ley you know.Thanks.Dobs.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    blown bulb then , you have 2 side lights each side , the top smaller 1 is also the brake light .
    so if the right stop lamp is bigger then it is using the next bulb down .
    May 2011
    South London
    Ah the "old switch-eroo" trick
  1. what can cause a brake pad check light to appear randomly?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2012, 17:42
  2. Check Brake Light
    By gavmckay in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2012, 11:15
  3. Check brake light switch
    By dolf.peeters in forum Engine & Drivetrain
    Last Post: 5th July 2011, 00:55
  4. Brake Light Check
    By tangoman in forum Electrical & ICE (including SatNav)
    Last Post: 18th October 2009, 22:11
  5. Check rear brake light.
    By rushy in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2007, 20:04
vectra brake lights. one is higher than other
vectra c check brake lights
vauxhall vectra 2.2 check brake light
check right brake light signum
