Thread: Front spring replacement
    Regular Member maz's Avatar
    Lincoln
    Default Front spring replacement
    Right, I had a spring replaced on the front of my vectra a couple of days ago as it failed the MOT with a broken one. The ride height on the front is a little higher than the back now by a good couple of centimetres. Is this normal? I appreciate that over time they bed in but I've had a replacement before and it didn't look as high and on an SRI the ride height tends to be lower.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    U should replace in twos mate never replace just one
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Sounds like who ever fitted your springs has fitted standerd springs , SRI,s are 15 mm lower than the standerd set up
    and still loving it
    Lincoln
    Problem solved. Was the right spring height but the wrong lb weight. Vauxhall sent wrong one suprise suprise.
  1. rear spring replacement
    By flimbyx1 in forum Suspension, Wheels & Brakes
    Last Post: 19th April 2012, 13:30
  2. Irmscher Spring Replacement
    By honigstrauss in forum Suspension, Wheels & Brakes
    Last Post: 14th April 2012, 17:25
  3. spring replacement afl light now flashing
    By iceeee in forum Suspension, Wheels & Brakes
    Last Post: 24th February 2012, 18:06
  4. rear spring replacement
    By meathead in forum Suspension, Wheels & Brakes
    Last Post: 17th January 2010, 04:49
vectra c front spring replacement
https:www.vectra-c.comforumshowthread.php174078-Front-spring-replacement
vectra c 2.0 dti front spring replacement
