Thread: Engine cut out
    Jul 2011
    UK
    Year : 06
    Default Engine cut out
    Missis just rang said the engine cut out struggled to start it started then further down the road it cut out again Its running now ok no warning light came up nothing car is 2007 cdti 150
    Full Member coldo's Avatar
    Scotland
    Not great when that happnes.
    Can you get access to Tech2, OpCom or similar to read the faults from the ECU and they should have been loged...
    You did also check she wasnt on her way to the pertol station and now its running because she filled it up?
    scottish region
    Any codes with pedal test
    Jul 2011
    UK
    Year : 06
    It happened after she put fuel in and it cut out in the middle of a roundabout not got a code reader yet so can't read codes if any and the pedal test don't work on mine it's been fine with me al yesterday afternoon tho
  1. Replies: 5
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
