Thread: Fitting jvc headunit problems!!!
    Regular Member Marvec's Avatar
    Oct 2012
    preston
    Cool Fitting jvc headunit problems!!!
    Hi im new to this site so hopefully i will get some good advice.
    I have a 2005 vec c 1.8 petrol and i want to change the headunit, (single din) i have all the kit but when i connect my jvc headunit it doesnt work, you can only put a cd in and eject it as the motor works but no lights/sound come on . This headunit has worked in all my other cars but the vectra, there is power going to the jvc but it seems its not enough, here are some pics of the kit i have.
    Pic 1 Antenna Adaptor.
    Pic 2 Quadlock Adaptor
    Pic 3 Headunit JVC KD-G632
    pIC 4 My original unit.
    Also, do I have the correct lead for the steering wheel controls to work?
    Jul 2011
    UK
    Year : 06
    Try swapping the power cables ie red wire into yellow and yellow into red I've always had to do this
    Regular Member coldo's Avatar
    Scotland
    In my experiance this is normaly down to the Const power and the ACC power leads being the wrong way round on the headunit harness.
    Your also coneccting it to a quallock which might need you to take power from another source due tot he canbus issues. What type of quallock lead are you using (make like Connects2, Autoleads etc)...?
    I am assuming the wiring haness from the headunit is not photographed. It will most likely connect into the ISO connectors at teh other end of the qual lead. If this is the case then UI would buy the following...
    http://www.dynamicsounds.co.uk/conne...or-p-9113.html with the JVC patch lead.
    This will let you efectivly plug and play the radio. Stearing wheel controls WILL work with this and still allow you to access the setting screen of the BD system to adjust the clock etc.
    You might be able to source it cheaper else where but I have always found this company to be very helpfull.
    Oct 2012
    preston
    Quote Originally Posted by marc vectra sri View Post
    Cheers for the reply, do you mean swap the red and yellow wires on the headunit or the quadlock lead?
    Scotland
    if your swapping the wires it will be the ones on the head unit wiring loom as they normaly have conectors to allow you to do this.
    Jul 2011
    UK
    Year : 06
    It's the wires on the headunit u swap
    Oct 2012
    preston
    Quote Originally Posted by coldo View Post
    yes the jvc headunit has swappable red/yellow leads, and the quadlock is made by Celsus, i bought it from my local motorstore, i will have another go at fitting the unit now
    Scotland
    The wires from the quadlock (orange and red) look like they need to be connected to something. I am assuming this is like the old Vauxhall astra H adapter whcih took a feed from the cig lighter or the sports button.
    Personaly I would ditch the lead (steering wheel controls will not work with it) and get a connects2 / autoleads or similar one instead which has the steering wheel patch. That way everything will work .
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    +1 on the dynamic sounds too, they're a great company to get stuff from.
    Oct 2012
    preston
    Quick update, i managed to get my JVC unit going as i connected my red wire to the yellow wire creating a live wire so i just have to pop the head unit off when the car is parked up, I might get the lead with the steering adapter on in the near future, thanks for all your good advice guys .
  1. Fed up - please help... Aftermarket double din headunit fitting
    By andyfeeny in forum Electrical & ICE (including SatNav)
    Last Post: 23rd July 2010, 19:42
  2. Headunit problems
    By jimmy k in forum Electrical & ICE (including SatNav)
    Last Post: 5th July 2010, 22:58
  3. Headunit problems
    Last Post: 5th July 2010, 15:52
  4. fitting new headunit
    By decks in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2010, 21:58
  5. Headunit Problems anyone???
    By Cilldara1 in forum Electrical & ICE (including SatNav)
    Last Post: 5th July 2007, 16:23
vectra c jvc connect
