Thread: Negative Camber
    Default Negative Camber
    I have negative camber on the off side front and none on the near side. The car pulls to the left as i am always steering to the right to compensate.
    Any Ideas. I have had a look and nothing seemd to be bent or broken.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Hmm, front's shouldn't have any, not sure if its adjustable on the front (others may confirm).
    Could be strut mounts maybe, do you get any knocking/rattles?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Front camber adjustment is minimal, can you see the negative camber in the wheel? Sounds like a suspension bush has packed in somewhere
    had a look under the car and there seems to be tool marks on the rods that are adjustable.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by Hursty103 View Post
    If you mean the track (tie) rods, then they won't affect camber.
    Regular Member coldo's Avatar
    Scotland
    Top mount or top mount bush prehaps...?
    Rod ends only affect the side direction and not the top bottom angle if that makes sense....
    Chelmsford
    I'd say your best bet is to get your car on a Hunter machine. www.alignmycar.co.uk
    They'll inspect the suspension, then run the tests and show you exactly what's wrong with the geometry.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by DNS View Post
    Most ATS' now have alignment machines comparable to the hunter machines - makes them far more accessible.
    i took it to kwik fit and when they had it on the ramp, thats when you noticed the camber on the off side and not on the near side.
  1. Positive -Negative camber?
    By SRI Heaven in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2010, 10:34
  2. Camber? Camber Kits??
    By RyanNI in forum Handling & Braking
    Last Post: 13th December 2010, 11:11
  3. negative numbers
    By mrk in forum Comedy & Humour
    Last Post: 11th December 2010, 15:52
  4. Negative Camber= Rear Tyre Wear
    By honigstrauss in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2010, 10:26
  5. Negative Earth
    By John2360 in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 20:30
