Thread: What size brakes
    Regular Member BBMadness's Avatar
    Apr 2012
    Merthyr Tydfil
    Default What size brakes
    Looking to find out whether I am running a different brake set up to standard on the front
    is a vectra pre facelift 120 1.9cdti
    All help would be greatly received
    Thanks in advance
    South east
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    More likely 285mm standard ...
    Apr 2012
    Merthyr Tydfil
    Thanks for the quick help
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    12 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    It will be easy to find out... If you're running 285 mm fronts, then :
    - The front calipers will look somewhat similar to the rear ones, just a bit wider ;
    - The rear brakes will use plain 278 mm dics, not vented 292 mm ones. Since there are only two kinds of rear discs, it will be quickly sorted out.
  1. What size brakes
    By sebadee in forum Suspension, Wheels & Brakes
    Last Post: 7th March 2011, 19:22
  2. What size are the brakes on the 2.2 SRi?
    By Nato in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2010, 13:48
  3. what size brakes
    By i5aces in forum Handling & Braking
    Last Post: 27th December 2009, 22:26
  4. What size brakes??
    By danBoy in forum Handling & Braking
    Last Post: 17th October 2009, 22:37
  5. what size are my brakes?
    By nev-vec in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 07:52
