Results 1 to 10 of 15
Thread: 1.9cdti 150 wont start after just after cutting out during run
    Jul 2012
    Staffordshire
    Default 1.9cdti 150 wont start after just after cutting out during run
    Hi
    I am in need of guidance. My 2007 1.9 cdti 150 Vectra C has 95,000 miles currently, I was driving it home tonight and after 35 miles the car just cut out as I changed gear from 1st to 2nd at an island. I pulled over and tried to restart, it did restart after a few attempts but would not rev, it then stalled and has not started since.
    I got it recovered to home and I have been on here all night looking for answers, my head hurts! he breakdown guy said he thought it was fuel and not fixable easily roadside and as I was soaking I was only to happy to get home.
    Things tried
    • Fuel checked for fuel pump
    • I am hear the fuel pump prime on key turn
    • Car turns over ok but wont start
    • Tried spare key
    • Car has juat under 1/2 tank of fuel, I have done about 200 miles on tank so far
    • Temp was normal about 85 degrees
    • Outside temp was about 11 degrees ambient and it was raining
    • Checked all pipes to see if anything has come adfrift, they seem fine
    Does anyone have other things I can check before I commit to a mechanic coming and looking at it?
    Thank you
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Need to check getting fuel upto rail.
    rail pressure. Etc
    does sound like a fuel fault
    no codes showing?
    Jul 2012
    Staffordshire
    Quote Originally Posted by Critch View Post
    rail pressure. Etc
    no codes showing?
    How do I check rail pressure?
    How do I get codes?
    wirral
    39 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Didn't know if recovery guy had checked anything an that's what confirmed his thoughts?
    needs diagnostic equipment
    Jul 2012
    Staffordshire
    I borrowed a diagnostic laptop and dongle from a friend, I ran it through the tests and come up with 2 faults. P0340-29 Camshaft position sensor open circuit and P0340-28 Camshaft position sensor range/parameters.
    Does that mean its a case of finding and replacing the camshaft sensor, clearing the fault codes and I am on my way? Or could it mean the camshaft has an error due to a possible snapped belt?
    I will have a search here now to try and find how to swap one...
    Jul 2012
    Staffordshire
    Well I got it diagnosed, after removing the cam sensor it was heavily deposited with gumk, far to much than healthy. I decided to remove the cam belt cover to check the belt and there was the fault, a very loose belt, further inspection revealed a faulty tensioner bearing so the belt has slipped and mashed the engine.
    So the fault is diagnosed and the repair expensive...
    Oct 2012
    lostockhall
    ouch glad i changed mine recently for peace of mind after owning a few month
    Oct 2012
    lostockhall
    if it will turn over correctly is it not worth puting a new cam belt kit on it and trying it
    surely if it will rotate theres nothing bent
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Take off cam cover see how many rockers are broke. These are meant to break to save engine you may be lucky.
    Jul 2012
    Staffordshire
    Quote Originally Posted by troutybrown View Post
    Knowing my luck I doubt it but thanks for the info, I will take it off tomorrow to have a look, after all it cannot hurt to pull it aprt a little more.
  1. 1.9cdti wont start following waterpump/belt fail
    By richsimpson in forum Engine & Drivetrain
    Last Post: 9th March 2011, 19:57
  2. 1.9CDTi Wont Start After Coolant Light On
    By s-owen4 in forum Engine & Drivetrain
    Last Post: 17th September 2010, 15:11
  3. 1.9CDTi SRi 150ps cutting out?
    By Keith Fusco in forum Engine & Drivetrain
    Last Post: 16th June 2010, 22:18
  4. 1.9cdti 150bhp stuttering and cutting out
    By llanddewi in forum Engine & Drivetrain
    Last Post: 11th October 2009, 23:51
  5. wont start 1.9cdti
    By otl1uk in forum Engine & Drivetrain
    Last Post: 19th November 2008, 20:11
vectra 1.9 cut out now wont turn over
2008 vauxhall vectra 1.9 cdti 150 wont start
