Results 1 to 3 of 3
Thread: HHmmmm Traction control light staying on
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Default HHmmmm Traction control light staying on
    As title says today i had to go to my brother-in-law work but on the way round the yard i had to go on the grass it was just the passenger side that went on and it was wheel spinning and when i stopped and turned the ignition off and back off i noticed the TC light was staying on so drove home stayed on all the way home so parked up switched the ignition off for at least 3hrs went to the shop it stayed off for a bit but came back on and stayed on anyone know what might be up ?
    What i thought is when it wheel spun it kicked up mud and maybe hit something?
    See if i put a reader on it will it give back a error?
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    try cleaning the abs connectors with a little contact cleaner as im sure the wires in them all work in conjunction abs/tc etc HTH
    Chelmsford
    Could be many things... As simplesi has said, the ABS sensors are all part of the ABS/TC system, so a failure of any of them, or the wiring will cause the TC and ABS to deactivate.
    I had this recently when I replaced a wheel bearing. New unit had a faulty speed sensor so the ABS/TC was disabled until it was fixed.
    If you know someone with Tech2 or "another diagnostic system" they should easily be able to narrow the fault down to a specific wheel or other component.
  1. PLEEEEASE HELP - traction control light/power steering light on!!!
    By holdenvectra in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2010, 23:39
  2. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  3. Traction Control light staying on !!
    By cjchapman in forum Suspension, Wheels & Brakes
    Last Post: 4th December 2009, 10:54
  4. Help abs & traction light staying on.
    By Teza in forum Suspension, Wheels & Brakes
    Last Post: 14th December 2008, 17:09
  5. traction control light
    By chosen1 in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2008, 09:02
traction control light on vectra c 3.2 v6
