Thread: Cam belt broke....and now fixed. Thermostat help next
    May 2012
    St ives
    Default Cam belt broke....and now fixed. Thermostat help next
    So driving home and the cambelt snapped....brilliant...2 days before my 2nd daughter was born
    This is the repair bill....anyone care to guess how much it was?
    Now next thing is the thermostat and sluggish starting.
    Reading through the forum ive come to the conclusion i need a new thermostat so looking at getting the newer version.
    My questions is this:-
    My car takes ages starting if left for a few hours, if i remove the little green clip on the thermostat (sensor?) the glow plug light lights up for a lot longer than usual and she starts first time.
    If i buy a new themostat will this fix the problem of my crappy starting.
    Discuss away.
    Alex
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Its a start, and the cheapest option before you replace the starter motor, battery etc
    Some replace the starter motor, battery etc and find it was the just thermostat.
    So pick what way around you want to start
    Good luck.
    Aug 2012
    this will be little comfort for you but my dads Scenic Belt went and after the 2000 pound rebuild was done it never started properly again. You would have to put ignition to glow plugs "on" position, then off, then back to glow on, then off, again and again before you could eventually go for a start. He put it in to Renault and nearly £900 pound later it was the same!
    May 2011
    South London
    Quote Originally Posted by jamesmcuk View Post
    Are you a "glass half empty" person ?
    Aug 2012
    Quote Originally Posted by C-Owner View Post
    No Mate,,, my glass is completely empty :-) I was just trying to give him a boost :-)
  1. thermostat fixed
    By iasha in forum Engine & Drivetrain
    Last Post: 12th February 2010, 18:02
  2. Just broke broke bit of my dash
    By Graeme in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2009, 17:15
  3. Faulty thermostat fixed.
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2008, 02:32
  4. just broke my key can it be fixed?
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2008, 21:26
  5. Infinity Basslink Broke - so I fixed it.
    By wrightgj in forum Electrical & ICE (including SatNav)
    Last Post: 9th August 2005, 13:11
