Thread: grinding into reverse
    Oct 2012
    birmingham
    Default grinding into reverse
    well since my vectra c had an engine change its been a struggle to get it into reverse with out it grinding can any one help ??? its 04 1.8ls
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by Daz d View Post
    Some things not aligned properly, make sure the gear linkages are all ok
    http://www.vxronline.co.uk/forum/sho...a-Gear-Linkage
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Sounds like gear cable not correctly adjusted. The car is automaticly in 1st gear when disconnected cables. And always need to be adjusted if new engine or new cable fitted.
    Chelmsford
    Has the clutch been bled?
    If it's got the tiniest amount of air in the line, reverse will be the gear which is noticeably difficult to select.
    Jun 2012
    Fife
    Its unlikely to be a gearbox issue, any problems entering reverse is because there is no synchro-mesh for reverse gear and the input shaft must be stationary.... if not you get the crunch. So it's a clutch issue, either not de-clutching properly as there is air in the system? (Pedal feel ok? Suspect faulty CSC drawn a gulp air due to being worn) or draging because the friction plate is warped? (Hold the car on hills with the clutch? Clutch judder when pulling away from rest?).
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    I bet me money the gear cable need re-adjusting.
    Mar 2011
    belfast
    I had the same problem with my 1.8 vectra after replacing the gearbox and engine, you need to adjust your gear linkage and it will cure the problem,
    to do this you will need to lock the gear stick into adjust setting and also lock the the linkage at the gearbox into neutral using a 5mm drill bit,
    the Haynes manual tells you how to do it,
    its easy.
    Oct 2012
    birmingham
    thank u all an goin to try it tomorrow day off work
  1. heavy breaking grinding
    By swvectra in forum Suspension, Wheels & Brakes
    Last Post: 13th October 2010, 20:51
  2. Grinding brakes
    By Chuddy in forum Handling & Braking
    Last Post: 1st August 2009, 14:02
  3. Grinding when going allong
    By Steven T Davies-Moss in forum Engine & Drivetrain
    Last Post: 7th January 2009, 19:13
  4. Gearbox grinding?!?
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2007, 23:54
  5. Grinding Noise
    By v6boy in forum Engine & Drivetrain
    Last Post: 10th October 2006, 07:52
vauxhall vectra 1.8 crunching when going into reverse
vauxhall zafira reverse gear crunches
vectra c wont go into reverse
Reverse gear grinding vectra
