Results 1 to 10 of 11
Thread: rear brake pad change
    Regular Member andy_richmond's Avatar
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Default rear brake pad change
    quick question, once ive changed the rear pads on my preface vec c, if the handbrake needs adjusting how do i do it, and do i need to do anything to it before i lift the caliper up to gte to the pads, may sound daft, first time on the vec c
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    Before winding the piston back undo the lid on the brake resivior. Once you changed brake pads use the footbrake to take up the slack (with engine running) pump pedal half adozen times. Handbrake is self adjusting.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    No need to touch the handbrake
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    jesus, spring pad was on the outside, and the inner one was at a 45 degree angle for wear. il post up some pics shortly, can sort of see why they were rattling. had to bleed them all after one piston wouldnt budge. and i just took it for a drive, pedal hit the floor and pulsed up and down, and no brakes. stopped, put handbrake back on, pumped the pedal like mad again, and they seem to have sorted themselves out now.
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    rear pads
    Full Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    someone have put those in wrong
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    i would say so lol
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    jesus christ, how did they manage that am mean the calipersquezes them together so it should be pretty flat ive never seen that before, i would mabe check that out, were the pads against the caliper piston etc flat?
    also, are u mad? u dont drive the car u just pump the brakes stopped where u r untill the pedal goes hard, then try them short distance before u go out onto the road
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Had already pumped till hard, pulled the hb a few times too
    Engine : 1.9 CDTi
    Looks like there were not seated in the carrier right.
    Did it do much damage to the disc as it looks like its had metal to metal on the end.
  1. Rear Brake Pad Change
    By chrisom in forum Suspension, Wheels & Brakes
    Last Post: 24th September 2011, 19:13
  2. brake pad change
    By kiwiboy in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2010, 07:47
  3. rear brake change tomoz
    By myelite150 in forum Suspension, Wheels & Brakes
    Last Post: 23rd February 2010, 19:27
  4. noise since rear brake change
    By magpie27 in forum Handling & Braking
    Last Post: 9th November 2009, 12:17
  5. Rear brake change
    By grumpano in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2008, 21:53
