Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: possible leak off problem
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Default possible leak off problem
    hi all...
    iv had the usual spanner on start up due to having bad glow plugs so i replaced them, but iv still got bad starting if the cars left for a good few hours.
    it usually starts first turn of the key but it sometimes cuts out not long after and i get no power at all and it then proceeds to start back up but very badly with a decent bit of smoke and lumpiness.
    could this be the start of leak off pipe problems?.. i dont get any warning signs coming up on the dash at start up so im guessing its the pipes.
    *engines a 2.2dti*
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    anyone?
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Are you able to see any data?
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Quote Originally Posted by Critch View Post
    data as in?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Quote Originally Posted by Al 22 dti View Post
    data as in?
    Al what Critch is asking is can you check for fault codes as this will give you some indication of what to look out for
    and still loving it
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    ah... not looked for fault codes as yet but nothing pops up on the dash when its starting up.
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    I meant live data view sensors voltages etcetera whilst fault happens may give you an idea at what's happening
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    cant find me bleedin code reader now lol.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    found it... no codes?
    it did its trick when i fired it up tho. no power for about 10-15 seconds even with my foot to the floor it wont rev beyond 1500-2000 and then it just picks up and its perfect driving from then on.
    if its left long enough, it fires up but usually cuts out and has to be cranked a fair bit.
    im guessing leak off pipes.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Started it up this morning and it fired up after a couple of turns which is right.
    What isn't right is it still has no power for a good 15 seconds for some reason. It's like if I pull away and I havnt got enough revs on, it stalls, but if I give it at least 2000rpm, it drives off as normal.
    I can even put my foot to the floor and it revs at about 250rpm per second and that's deffo not right. Once again when it gets passed the no power period, it revs to 5500 as normal
    As soon as its passed this powerless term, it drives perfect ?
  1. 2006 vectra 1.9cdti starting problem and i=oil leak on start up
    By tomstubbings in forum Engine & Drivetrain
    Last Post: 24th September 2011, 10:01
  2. cdti starting problem, air leak??
    By moff747 in forum Engine & Drivetrain
    Last Post: 28th August 2011, 19:57
  3. 1.9 cdti intermittent starting problem (air leak?)
    Last Post: 16th April 2011, 15:54
  4. Air leak problem
    By neill in forum Engine & Drivetrain
    Last Post: 2nd September 2010, 18:55
  5. Replies: 1
    Last Post: 15th February 2010, 19:58
