Results 1 to 10 of 29
Thread: Thermostat housing fitted. But...
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Thermostat housing fitted. But...
    Not much heat in the cabin... What am i doing wrong??? Its more warmer than before replacing... But no where hot enough!!! Am i missing something else??
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    did you fit the thermostat as well as the housing ? silly question i know but hey you never know lol
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    It's probably your air temperature mixer servo goosed on your air box a common problem do a search you will soon see.
    Regular Member Keif's Avatar
    In the Garage
    What temp is your engine running at?
    If normal, see the above post!
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by paulhb View Post
    Tell me more... Where do i find this etc etc etc
    Yes new thermostat fitted with housing.
    Went to a mate at the garage. He pumped the pipes. Now running low. Might be needing more pumping through!! But interested to know details about air temp mixer thingy
    redcar
    Did you end up fitting it yourself mate, was it much of a job, fitting mine tomorrow
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Did it with mate in garage. He made it look easy but hard part is slipping the rubber hoses off the fitting point. U need to slightly move with small slot driver then twist it to make it unstick then pull off.
    The fitting bracket is a pest to move. U'll see just under the thermostat... Bend it outward slightly to be able to remove it freely. U'll get some water gushing out but not too much lol. Dont forget to clean the area where rubber washer latchs to when new housing fitting back on. Dirt vs rubber. Dirt wins!!!
    Enjoy! :-) lots of bits to go around... Housing is bolted by 2 bolts top and lower side.
    Chelmsford
    Did you pull the hoses off the heater matrix when you refilled the system? I think you have to do this to get rid of any air in the matrix...
    redcar
    Quote Originally Posted by Humourbash View Post
    How long did it take roughly, i should be ok as long as i keep my cool lol
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Put heater temp on full, and remove the bleed screw on the front top coolant pipe until coolant flows out. This will ensure any trapped air escapes. Then take if for a run. Let is stand with it ticking over and watch the temp guage. Should increase up to 92 before the fan cuts in. Heater should be hot at this point
    In reply to what PAULHB said, I had my air temp mixer go on mine. Turn the ignition on but do not start the car. Put fan speed on 1, then adjust the air temp hot to cold and back again. Listen for the motor (very quiet) as you turn the temp up and down.
    HTH
  1. Thermostat housing
    By Robhousing in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2012, 18:54
  2. thermostat housing
    By alan66 in forum Engine & Drivetrain
    Last Post: 10th September 2011, 16:01
  3. thermostat housing
    By andy bo in forum Engine & Drivetrain
    Last Post: 27th July 2011, 12:54
  4. Thermostat Housing
    By coopey in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2011, 10:35
