Thread: SRI to VXR Front Bumper
    Full Member
    South West
    StatsVehicle Info
    Default SRI to VXR Front Bumper
    Hey All,
    Can someone just confirm the following for me... If i wanted to go down the SRI to VXR front bumper option, apart from the front bumper itself, i would also need:
    The fog lights (x2)
    Wiring Harness for the fogs (x2)
    I guess its a case of the wiring harness then plugging into the existing fog connections?
    Also, what is involved in getting the washer jets on the bumper operating?
    Aidi
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    StatsVehicle Info
    Do you need fog lights? Are they different?
    Insignia VX-Line Nav CDTI 170.
    Full Member
    South West
    StatsVehicle Info
    I am pretty sure they are different to the ones fitted the SRI bumper - and require additional loom to make them work.
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    StatsVehicle Info
    Yep, they're completely different. VXr fog light are completely round and are fitted from behind the grill with 4 screw-on lugs.
    You'll also need replacement center and fog grills (plus the optional chrome surrounds if you want, that fit from the rear, between the grill and the round fog light).
    I wasn't sure about the loom ; VXr fog lights use H11 bulbs whose plug will protrudre outside the projector housing, so the loom should directly plug into the bulb itself rather than into an intermediate connector.
    However, maybe the SRi fog light housing connector is compatible already, so you might still not need any extra loom.
    I really don't know there actually, and opeloem.com being down doesn't help... I was storing the Vectra C part of the site when they brutally cut it down... The required picture is in the "P" section, and the capture unfortunately stopped at the "M" folder !
    However, the TIS does show a unique loom connector that really looks the same as the one that would be needed to plug into a H11 bulb, so chances it's OK already are very high.
    Full Member Penfold101's Avatar
    StatsVehicle Info
    I managed to download the entire site before it went down...
    Took a day and almost 5GB but its all there somewhere if you need it...
    Full Member Sebastian's Avatar
    Electric Heated Recaro Leather
    26 Post(s)
    StatsVehicle Info
    26 Post(s)
    Yes is complete new bumper , and foglights are different , as for wiring harness u only need adapters which they ate 7£ ish from dealers.,,, for installing headlight washers u need new washer bottle with pump, extra plug for pump itself or retrofit one, house and washers , tech2 or Vauxcom required to enable them....
    26 Post(s)
    StatsVehicle Info
    26 Post(s)
    Here u go taken from styling section guide made by BigPete :Vectra (XP) upto MY2008
    9271527 VXR / XPII FRONT BUMPER (Top Half) (1) (regardless of AFL washers or Parking sensors) £319.00
    9271528 VXR FRONT LOWER SPLITTER (1) £136.00
    9271521 VXR HONEYCOMBE LOWER GRILLE (1) £25.45
    9271523 VXR UPPER HONEYCOMBE GRILLE (1) £24.87
    9271518 VXR O/S FOG LIGHT GRILLE (1) £24.05
    9271517 VXR N/S FOG LIGHT GRILLE (1) £24.05
    93186621 VXR CHROME FOG LIGHT INSERTS (2) £6.67 each
    9270157 VXR FRONT FOG LIGHTS (2) £65.00 es
    9270158 VXR FOG LIGHT WIRING HARNESS (2) £3.20 ea
    9271533 VXR PRIMED V GRILLE (1) £42.30
    9271524 VXR TOWING EYE COVER (1) £30.00 ('ISH)
    93160447 PARK PILOT FIXING KIT (if you have front parking sensors) £13.62
    24449408 NUT CLAMP (6) £0.60p
    90450482 FIXING (4) £0.84p
    90087290 RIVET (4) £0.52p
    90508809 RIVET (4) £0.48
    90138810 RIVET (30) £5.40
    Prices are out of date tho so be prepared
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    StatsVehicle Info
    are these the small black plastic type used for holding the bumper in place on the preface
    Full Member
    South West
    StatsVehicle Info
    Magic, i did actually find the list after posting but thanks anyway. Just need to decide now if i want to go ahead....
  1. Signum front bumper (Vectra c pre-facelift sri bumper) rubber skirt
    By 2.2 DTI SRI in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2012, 20:23
  2. Rear Bumper Repair GSi, Front Bumper soon!
    By Vectra_C_Chris in forum Quick Photo Album
    Last Post: 7th June 2011, 12:32
  3. Replies: 8
    Last Post: 11th March 2008, 19:28
