Thread: parking sensor location points
    Nov 2009
    Warrington
    Default parking sensor location points
    just a quick one, for anyone whos fitted parking sensors. am i right in thinking every vec c rear bumper has the sensor location marks on the back of the bumper ?? got a set off ebay today and will be fitting them soon (after ive sprayed them)
    scottish region
    Yes that is correct Rob
    Nov 2009
    Warrington
    Quote Originally Posted by DAVIDD88 View Post
    Good man, thank you David. I'll take the bumper off and do it rather than mark it all out on the front. Cheers
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    14 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    I wasnt aware of that and put them differently, slightly higher (above the number plate recess) because this part is really vertical, and placed the outer ones a bit inward, as compared to standard fitting.
    I regret I did that : there are dead angles and I'm not warned when there's something facing the bumper's corners.
    You should stick on the existing marks, if you can find them on the back of the bumper.
  1. sensor location
    By stret in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2013, 18:01
  2. Crankshaft sensor location
    By lilangel in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2011, 12:06
  3. Location of Adjustment Points For Rear Camber
    By marcdale in forum Suspension, Wheels & Brakes
    Last Post: 30th May 2008, 09:29
vauxhall vectra parking sensors location
