Thread: vectra sri 150 brakes
    Regular Member tazdog03's Avatar
    May 2011
    barnoldswick
    Lightbulb vectra sri 150 brakes
    hi im in the process of fitting of fiiting the 314mm upgrade to the front. what do you all think i should do with the rear please?
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Signum 2.0 DTI (Irmscher)
    Trim : Elegance
    Engine : 2.0 DTI 100 bhp
    The rear does so little braking overall that it makes little to no difference other than asthetics if you want to upgrade them too.
    The only time it would be worth thinking about is if you run your car on a track or were going to do major engine upgrades. I would save your money and spend on other areas of the car (remap).
    May 2011
    barnoldswick
    cheers brifen
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    14 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    If I judge from pads wearing, the rear doesn't do so little braking.
    I upgraded the rear to 292 mm vented brakes at the same time I upgraded the front to 314 mm.
    Used parts are not so expensive you should hesitate. Be warned you'll have to replace the heat shields, though. I didnt' have to do it at the front, as the small ones for GTS (SRi) are the same for all sizes (same as VXr/OPC ones, BTW) : they only protect the lower joint from the disc heat.
  1. Vectra Brakes
    By 1.9VCEstateChris in forum Suspension, Wheels & Brakes
    Last Post: 15th June 2012, 22:09
  2. vectra sri cdti 150 brakes
    By stanlee in forum Suspension, Wheels & Brakes
    Last Post: 8th August 2011, 21:16
  3. vectra vxr brakes
    By signumturbo04 in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2010, 16:04
  4. vectra vxr brakes
    By tbs in forum Suspension, Wheels & Brakes
    Last Post: 19th November 2009, 22:27
  5. vectra b big brakes
    By TIMMAH in forum General Chat
    Last Post: 31st January 2008, 10:35
