Thread: hello there...
    Oct 2012
    tamworth
    Default hello there...
    hi all... another veccy owner here on the look out for some info lol....
    ive had mine now for over a year and a half , loving it as its the 1.9cdti 150 ps engine
    but now is starting to cause some uneasy baldness from head scratching..lol
    i have a couple of issues , wich im sure i will get pointed in the right direction...hopefully
    1. i have recently replaced the rear wheel bearing hubs due to a whoowhoo whooing noise at certain speeds and increases in volume when going round a roundabout for example.. and now have an intermittent abs/tc error on the dash prior to it illuminating the brakes when applied even just lightly seem to set off the abs(judders), it seems to happen 95% of the time after ive reversed off the drive...(oh and the whoowhoo noise is annoyingly still there.....)
    2. when cold the gears are hard to engage, like theres something impeding the movement and feels notchy..it happens when changing into second and third unless i let the revs drop first, it improves when warm but not altogether, i am contemplating oil change and adding the additive too... hopefully that will fix it but any advice is appreciated...
    thanks in advance..
    hope i can get my veccy back to tip top soon with ur helps
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Welcome to vec-c
    Oct 2012
    tamworth
    cheers.....lol
    Regular Member Dippy-Vx-line Red's Avatar
    Earlston (Scottish Borders)
    Hi and welcome to vec-c...I also have the notchy gear change which others on here have too..I also have noise from wheels but i`m putting that down to my snowies.
    Oct 2012
    tamworth
    when your cornering or all the time?
    i get a noise when turning to the right. Had drivers side wheel bearing changed not long ago and all others are fine..
    Chelmsford
    The droning noise on the back is often caused by worn upper control arms causing the rear tyres to wear unevenly. I had this a while back, it makes a sound very much like a duff bearing. Feel round the tread of the rear tyres, with mine I could feel noticeably raised sections on the inside edge.
    Where did your new bearings come from? There are a few cheap ones making the rounds which have faulty ABS sensors (I did a front bearing last week and had this, as did another member)
    Oct 2012
    tamworth
    got it off of ebay, paid £80 for the pair
    item number..... 280907025686
    link...... http://www.ebay.co.uk/itm/2809070256...84.m1497.l2649
    im in the process of gettin a replacement sent out but need to buy another set from them to get it sent out n duff ones picked up... just hope i get a refund on original ones..
    and means the veccy will be up on axle stands till they arrive...
    grrrrr
    Oct 2012
    tamworth
    Quote Originally Posted by mikeywasall View Post
    grrrrr
    ...... holding fee £39.99,,
    free redelivery of new set and free courier collection of old hubs when ive taken them off and fitted new ones..
    now thats good customer service!!
