What benefit would these 2.0t upgraded injectors give my 2.2 Direct?
http://www.ebay.co.uk/itm/Saab-93-B2...item27cbfd489d
Well those blue ones are 261cc or there abouts. If these are bigger than your standard injectors then you may see a difference but only with a remap otherwise you will overfuel the engine.
If they're bigger than his current injectors, then I'd say they aren't of any use to him, because without a turbo how will the ECU increase the supply of air to match the increased fuel supply?
With Maptun you can go to stage 2 (actually the 3rd stage as there's a 1+) without changing the turbo but by fitting the larger injectors. The standard garrett turbo is good for 16psi of boost.
But as Nige says, you need a map for the car to know how to use the larger injectors or you will just over-fuel the engine.
Ahhh... the perils of quickly scanning a thread without going in too deep...lol. He's got a 2.2 Direct, not a 2.0T so no turbo.
LMAO, yeah, ok I didn't read it properly...
Consider me properly ashamed
Probably not worth it then, even if I went for a cat back system, panel filter and remap, adding the injectors wouldn't give me much of an increase over an already quite limited bhp increase I assume.
agreed..
True. hadn't thought about it that way. Thanks, I'll let them go then...
