Results 1 to 10 of 14
Thread: 2.0t Upgraded Blue Injectors
    Jul 2011
    UK
    Default 2.0t Upgraded Blue Injectors
    What benefit would these 2.0t upgraded injectors give my 2.2 Direct?
    http://www.ebay.co.uk/itm/Saab-93-B2...item27cbfd489d
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Well those blue ones are 261cc or there abouts. If these are bigger than your standard injectors then you may see a difference but only with a remap otherwise you will overfuel the engine.
    South east
    If they're bigger than his current injectors, then I'd say they aren't of any use to him, because without a turbo how will the ECU increase the supply of air to match the increased fuel supply?
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    With Maptun you can go to stage 2 (actually the 3rd stage as there's a 1+) without changing the turbo but by fitting the larger injectors. The standard garrett turbo is good for 16psi of boost.
    But as Nige says, you need a map for the car to know how to use the larger injectors or you will just over-fuel the engine.
    South east
    Ahhh... the perils of quickly scanning a thread without going in too deep...lol. He's got a 2.2 Direct, not a 2.0T so no turbo.
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    LMAO, yeah, ok I didn't read it properly...
    Consider me properly ashamed
    Jul 2011
    UK
    Probably not worth it then, even if I went for a cat back system, panel filter and remap, adding the injectors wouldn't give me much of an increase over an already quite limited bhp increase I assume.
    South east
    Quote Originally Posted by ijk571 View Post
    Worse than that, I reckon the engine will never get enough air in it for the ECU to be able to produce the correct air/fuel mix.
    Jun 2009
    South Coast
    agreed..
    Jul 2011
    UK
    True. hadn't thought about it that way. Thanks, I'll let them go then...
  1. VXR upgraded
    By bembo449 in forum Insignia car chat
    Last Post: 3rd December 2011, 19:45
  2. Vac hoses upgraded
    By paul_sri150 in forum Diesel Engine related
    Last Post: 15th February 2011, 00:22
  3. upgraded
    By tonyv6elite in forum General Chat
    Last Post: 9th April 2009, 17:55
  4. Upgraded Brakes
    By sycho666 in forum Handling & Braking
    Last Post: 4th September 2008, 19:19
  5. My car's been upgraded ?
    By craigmerry in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2008, 08:21
