Thread: Is it possible to change Aux belt from top on CDTI SRI 150
    Redcar
    Default Is it possible to change Aux belt from top on CDTI SRI 150
    Ive got no Jack as its borrowed out and was wanting to do it this weekend. Can i do it from top if i remove air box or will i need a jack. Also is it easy to do? Thanks Guys
    Carnoustie
    You might get away with it if you take the plastic cover off inside wheel arch, it's all done from top anyway, just for feeding new belt over pulleys as it needs to be on right or it will get shredded!!
    Ronnie
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    you need to support the engine as you have to take off the mount and you need to be able to jack the engine up to gain better access to the tensioner ect
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Not for the aux belt you dont
    Jun 2012
    lancashire
    pmsl I was thinking cam belt
    Carnoustie
    Quote Originally Posted by John IS3 View Post
    That's what I thought! only need engine mount off for timing belt
  1. cdti 120 belt change
    By xf8u39 in forum Engine & Drivetrain
    Last Post: 19th September 2011, 15:05
  2. SRI CDTI 150 cam belt/waterpump change
    By Nick_206_180 in forum Engine & Drivetrain
    Last Post: 12th October 2010, 18:18
  3. 1.9 CDTI problems after cam belt change
    By oxenburger in forum Engine & Drivetrain
    Last Post: 15th June 2010, 10:42
  4. Vectra 1.9 CDTI cam belt change
    By bravenger in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2009, 10:47
  5. 1.9 cdti sri and 3.0 v6 sri belt change ?
    By STAV in forum Diesel Engine related
    Last Post: 24th June 2008, 16:11
https:www.vectra-c.comforumshowthread.php173938-Is-it-possible-to-change-Aux-belt-from-top-on-CDTI-SRI-150
