Thread: changing the fuel pump on my 2.0 dti!!! HELP!!
    Oct 2012
    middlesbrough
    Default changing the fuel pump on my 2.0 dti!!! HELP!!
    Hi there I'm new to this site so don't know how things really work but I'm really for advice on what steps to take on changing the fuel pump on my vectra 2.0 dti, I know its a realy big job but can anyone actually giv me a guide or any tips to take whilst I replace it. Thanks in advance
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    First thing you need is a lot of money and the. The pump is psg16 so it's high pressure on the engine also the ecu is built in to it well half of it is
    Oct 2012
    middlesbrough
    Hi yes I already have bought the new pump I am going to be swapping them over but I do understand that all the timing chain has to come off if I'm correct and also if its a different coded pump it will need recoding all that I think is left to do is just the hard graft but correct me if I'm wrong is ther a lot more to it.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Yep it needs recoding mate u need the ori file back on the car as the ecu is built in to the pump
    Oct 2012
    middlesbrough
    What you mean, like what's the ori file mate
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    You carnt put the file back on the ecu there is only Vauxhall and me and one more member on here that could change the file over the ecu needs recoding to your car
    Oct 2012
    middlesbrough
    Ah right mate I get ya, do you have any idea of wat that would cost
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Not sure tbh fella never had to go to Vx for out like that I suppose you could ring and ask
  1. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  2. Replies: 19
    Last Post: 30th May 2012, 15:53
  3. Found a small bit of tissue when changing suspected fuel pump
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd November 2011, 20:44
  4. high pressur fuel pump and fuel regulator ?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 12:23
  5. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
